- LED +/- pads are 2.0mm in diameter. They are positioned almost exactly across from each other (within a 0.1mm tolerance of exactly across from each other).
v003
v003
Even better do you have an estimate on how thick this would be assembled? and you didn’t say anything about shaving on this one like the 15mm single sided, is it possible to shave this one to 11mm?
I still dream about a single sided dd fet driver with one of these modern tiny FETs in 10-11mm, is something like that even remotely possible? maybe if you use the smallest smd’s like the 0603,0402,0201 or crazy tiny 01005.
Edit
You are developing drivers so fast you didn’t have time to add this one to your signature
I wish the post office, the slow china holiday mail and my modding skills would move as fast as you are developing new drivers i may newer get a chance to try them all, i think this will be an interesting 2015 :party:
Lol his signature is getting out of control. Wight needs his own sub-forum
Nice, another great addition to the Alex Wells driver family.
One recommendation: to make that batt+ strap you really want an extra batt+ solder pad on the other side of the MCU, just a dummy pad going nowhere (there's room for it, it seems) so that you can solder a wire over the top of the MCU and fix it on the other side, for a simple batt+ contact point.
I agree, signature is getting out of control.
Copper is available for that end of the strap. It’s covered, users just need to scrape. I didn’t want to make the decision for them on where the strap should attach at that end. (Clearly the other end should solder to R1 or the R1 pad.)
Ah, that's great then, I did not notice the continuity between the R1 top-pad and the tracing on the other side of the MCU :-)
Ah, that’s great then, I did not notice the continuity between the R1 top-pad and the tracing on the other side of the MCU
Just to be clear, although you probably realize this: There is not a super-duper amount of copper connecting R1 and the big copper-covered area labeled “BLF”. That area is there primarily to allow a person to solder the strap in place - that’s it!
Thanks wight, maybe add the estimated height and possible shaving option to 11mm to the OP? these smaller builds is often as much limited by hight as by width so i think it would help getting an idea where i could fit.
I actually don’t understand what “strap” means in this context, are you referring to the bat +, one would have to place over the mcu?
Ok nice so it is possible to fit in 11mm that opens up some more possible hosts something like this could fit widthwise anyway, height is still a question thought.
The 10mm layout i was wondering about was a single sided 10-11mm with only a small DD FET, mcu and as small as necessary smd’s without the 7135 like your A17DD-SO8, for a tiny and slimmer option, if something like that could be fitted on one side with your new understanding on how tight you can place these tiny FET’s, if you only use the tiniest footprint needed like these 2 new drivers.
If some shaving of the attiny or fet is required that would be worth it, if thats would make it possible i think.
I actually don’t understand what “strap” means in this context, are you referring to the bat +, one would have to place over the mcu?Ok nice so it is possible to fit in 11mm that opens up some more possible hosts something like this could fit widthwise anyway, height is still a question thought.
One possible way of building a 10mm single-sided driver with an ATtiny13A and LFPAK33 MOSFET is to stand the MOSFET on end. You can easily trim 0.5mm of length from the MOSFET, so I’d expect the full standing height of the driver to be 4.4mm including the PCB. You’d need to move down to something small, probably 0402, and I think there would be an issue with C1 (it would probably need to remain 0603).
v005:
https://oshpark.com/projects/YUYEfb8i
excuse my noobness….
but I’ve been wondering this for awhile. What is the purpose of the vias everywhere?
A via is a plated hole. It electrically connects things on both sides of the PCB.
If you like, download and install gerbv (it’s a free program) and then go to OSH Park and download the zip of one of my boards. Extract the zip and load the files as layers into gerbv. This may help you see what’s going on.
so there are actually 2 layers of traces that need connecting at certain points through the pcb layer? That makes much more sense now.
These are double sided PCBs, so there are traces on both the top and the bottom. That’s why the OSH Park images show both sides. Single sided PCBs are only used in a small number of specialty situations these days. If you take a look at the PCB (s) you recently got from RMM you’ll see that it has traces on both sides.
easilytrim 0.5mm of length from the MOSFET, so I’d expect the full standing height of the driver to be 4.4mm including the PCB. You’d need to move down to something small, probably 0402, and I think there would be an issue with C1 (it would probably need to remain 0603).
Thanks for thinking this over and filling in my blanks of understanding in this.
Ok, so one possible way could be to stand the LFPAK33 FET up if you wouldn’t have told me the difference between a linear fet driver & dd det driver just yesterday i would have thought that it would be overheated when standing up with less heatsinking.
some different ideas……i hope some of these could make it a little bit more possible.
What if one used the PowerPAK SC-70-6 2 x 2 or the 1,9mm x 3 mm PowerPAK-8 size FET + the attiny13a-ssu, would it be possible to squeeze everything together so i could fit then with small smd’s?
Or would it be possible to place the smaller 3x3, 2x2 FET under the attiny13a-ssu if you bend down the legs so it could fit?
Or is it possible to use one of the other packages that the attiny13a come in something like the ATTINY13A-MMU 10M1 MLF that one is 3x3 and should take much less space on the pcb without those long legs, programming it i guess is only possible before the reflow or maybe there is tiny bits of legs that is accessible after.
Can you explain to me what you mean by clearances / keepouts?
EDIT
i haven’t succeeded in quoting only parts of someones post, thats why it gets a little long.
EDIT2
not anymore thanks to Rufusbduck
Select the text you want to quote then copy/paste using the quote button in the text editor.
Thanks Rufusbduck, now i finally got how to do it
I got a new nice 10440 host today the Jexree mini 5$, a very nice little aaa light but it goes single mode when i use a 10440.
Every part is easily accessible, lens,led star,driver,even the bottom spring. Driver compartment is 6,6mm deep, driver is 12,6mm wide, led star sits on a shelf thats is 13,8mm wide.
So i wonder, is it possible to make this 12mm driver a little wider for maybe 13mm sanded down to 12,6mm for a nice i hope press fit, or the even better fit for this because the driver sits on a little shelf, the single sided 15mm DD FET 7135 driver to 13mm sanded to 12,6mm if you use smaller smd component and if needed stand the FET up.
Or only the MCU+LFPAK33 FET, would that make a single sided 13mm driver sanded down to 12,6mm possible?
I am sorry wight if i ask for to much, i really don’t know how much work anything like this would be to figure out, but i kind of got it in my head that i really want to build some really tiny and really powerful lights, but i don’t yet have access to or currently enough fabricating skills to rebuild a light for whats available.
That’s the same light I had in mind for this driver,but I haven’t received mine yet. How deep is the pill area in the flashlight? Deep enough to push this one up inside and use a contact board?
Good choice, i bought a bunch of nice little aaa lights in hope of finding my perfect host, and this one really hits the spot it is small but surprisingly roomy where it needs to be. and it is as of yet the easiest and fastest flashlight to disassemble i have got so far.
And it headsinks really well for something this tiny, the whole flashlight gets warm quick when using a 10440 not just the head like some with worse heatsinking.
When you say pill area do you mean how deep is the part where the led star sits? that is 13,42mm deep without the bezel.
Or do you mean the part under that, because from the other side the one i call “driver compartment” is 6,6mm deep so because wight said this driver could be assembled in just under 5mm, we would have 1,6mm to spare for a possible contact board, but that would not leave much room for wires so it would be really fiddly to assemble if even possible.
Edit
This is wights answerer about the hight of the assembled driver
“Without your strap? 4.9mm w/ a mediocre build. 4.8mm w/ a good build (optimal amount of solder, 7135 and MCU both right against the PCB). Should be able to sand components down somewhat. Best case scenario I think you could reduce the top side by 0.5mm (limited by C1) and maybe the same on the bottom side (I don’t know how far you can sand the ATTiny13A). After all that you’ll have to add your strap’s thickness.”
So 1,7 + possible if one would sand down some components 0,5+0,5mm more so 2,7mm for an extra contact board and wires, still tight though but better
