I have made some prototypes with 7mm inductor, linear moonlight, voltage monitoring and ramp programmable modes (I don’t have the linear ML and VM programmed in my firmware yet). The problem is that I don’t have enough time to play with it. I need to make one more version with more space for diode so maybe I’ll end with just 5mm inductor. My previous versions used small diode and it didn’t perform very well. I also made a nice board for ATTiny10 but I realized that it doesn’t have an eeprom too late :-/ I have some useless boards now.
Nice! 15mm drivers open up the possibility of modding most AA-sized lights.
And if it is all going to work: will this driver have:
a) a decent efficiency compared to other boost drivers
b) a decent output current on a 1.2V NiMh battery, like over 1A through a XP-G2 emitter ?
In other words, apart from being able to have a custom UI (which is a wonderful perspective in a boost driver!), does it also outperform the middle-of-the-road boost drivers that come with cheapie lights?
7mm inductor is quite large, is there a benefit for this application?
What component size and footprint size are you using?
I think your layout is never compatible with SOIC programming clips, right?
I will study your layout, besides teh programming clip compatibility it looks nice to me.
Don’t get too excited djozz! The PAM2803 is only the normal boost controller we find on common boards such as DQG AA/AAA lights, Fenix E05 (& probably others), DX SKU#128084, Nanjg-110, and many others.
The answers to your questions are “maybe” and “no”. No, it will not put out 1A from a single NiMH. The datasheet has a good and easy to understand graph on that subject, please take a look. Efficiency? I expect that to be similar to other similar drivers such as the ones mentioned above. Take a look here for HKJ’s review of the 400mA Nanjg-110. It is not very efficient: no surprise!
No comment on running it with lithium cells. It is a boost controller with a cap of around 5v for output and a minimum of around 0.9v (startup) voltage for the input. It’s intended for applications where input voltage is lower than LED Vf. Generally speaking that means that it is intended for driving white LEDs on 1xAA, 2xAA, or possibly 1xCR123A.
Am I right in thinking that Pin5 (VOUT) is simply a voltage feedback pin?
The pin descriptions in the datasheet are not very useful. We’ve already got other pins for Switch and FB/SENSE, so I can’t imagine VOUT being anything but voltage monitoring…
Sure it should be a feedback for oscillator. It’s 5am now and I’m having finals at nine so I will get back to you later. Tomorrow probably, after getting some sleep
Thanks driveX. I have updated my layout. For now I have assumed that VIN can have a small trace. Please let me know if you think that this is incorrect.
Made a new 0805 footprint (based on the Eagle one) which I hope to be meaty enough for easy hand soldering and inspection. The pads are the same distance apart from each other, but they are both less long and less wide. The white tdocu markings showing the component outline are the same as the stock Eagle 0805 footprint.
If you are willing to aggressively shave your SOIC programming clip or give up onboard programming, a 5.0x4.5mm rectangular inductor will fit (or a 5.5mm round one). With a 4.0x4.0mm inductor an unmodified SOIC clip should be a snug fit.
I used Eagle’s big, stock, 0805 sized footprint for the Schottky diode. This should have enough space for an adequate one, but if you need to use a bigger one you’ll just have sacrifice the SOIC clip.
There are 3x 0805 components on the board with no identifier. These are all 10uF capacitors.
LED- is at the top next to Rs / LED+ is at the bottom on the end of the capacitor.
What would happen if the driver was built with a high resistance sense resistor for a current a bit above the requirements of the drive and a barely glowing LED AND a FET in parrell with the sense resistor so to increase the output, the micro controller would have the FET turn on? I’m not sure that the PAM2805 will take kindly to this kind of treatment or if it would actually do anything for efficiency on lower modes.
H-man, I have to completely agree with Alex here the circuit in the boards above is the correct use of this boost iC, can you link to a datasheet your looking at or why it is exactly you think adding those components would do anything different / better?
Can we back up (probably a topic for its own thread) but what is it your trying to do? Just have a higher current boost driver?
Don’t FETs of the size being used has an on resistance similar to that of the feedback resistor (~130 mOhm)?
The intent is to have the driver have a low mode without having it bounce off of the voltage limiter. My line of thinking is that with 2AA on lower modes, the PAM2805 would have to boost the voltage from ~2.4V to something below 3V with the FET off and then only have to boost to the relatively high voltage necessary to run the desired current through the LED when it is being pulsed. The current design has the PAM2805 bounceing off of the voltage limiter when the FET is off, right? That can’t be terribly efficient.
RE: The PAM2805 burning up: I shorted out the sense resistor on a boost driver that looks to be built around a PAM2805 or similar, it did not burn. There may have been some resistance in the circuit, but bypassing the sense resistor bumped current being pulled off of 2 eneloops from 1A to nearly 2A.
Has anyone prototyped this circuit? The basic PAM2803 circuit can be harvested from this cheap driver. Actually, that driver can be connected to any BLF DD driver for prototyping.
IIRC I haven’t actually shared this driver yet. I haven’t ordered or built any. Thanks for linking to a cheap donor driver for the parts. Now I’m somewhat more interested!
Maybe if you are very careful. You’ll probably break the GND ring on top and have to rely on the GND ring on the bottom for continuity between the GND vias. I thought that those lights used a 15mm driver?
Hmm, I see what you were going for now. Personally I still think it’s a bad idea. The on-resistance is not a static value, or even “near static” like a passive resistor’s value (which does still change with temperature). On-resistance changes significantly based on both input voltage and load. Unless someone spells it out for me that this idea will reliably function, I am going to assume that it will not reliably function. Ah, now I see that you’ve actually done an experiment.
Interesting. In that case, maybe the idea is viable. I still think that it will be prone to burning things. If the PAM280x doesn’t burn instantly it can still burn over time. Of course the next question is also whether anyone actually wants a 2-mode 1xAA / 2xAA driver? (I’m asking, not telling.)
As far as the bouncing off the voltage limiter business… I wouldn’t worry about it. These things have terrible efficiency in all cases I’m pretty sure…
If you PWM the FET, you can still use PWM in theory (in reality, it may fail hilariously.) I’ve tested a shorting of the sense resistor, I haven’t tested long enough to trust it but if the efficiency is still horrible, that point is moot because the whole point of this would be to try to improve efficiency. Are there no efficent boost ICs?
BACK ON TOPIC: At this point, just being available will make this the best boost diver for multimode AA/2AA lights because I don’t think there is a single microcontroller driven boost driver for AA/2AA/CR123 on the market right now.
Would there be any benefit to using a remote mounted toroid choke in this driver?
that’s a nice one. I like the idea of a “Nanjg 110 with modes”. I built some lights with the Nanjg 110 as it seems to be the best of the bunch of 1-cell-boost-drivers and I prefer Eneloop-torches for the kids.
Some ideas for the layout:
Why suddenly PAM2805? 2803 and 2805 are not pin compatible and your circuit in post 13 follows mostly the 2803 datasheet circuit, except for the capacitor between Pin-1 and GND. No such with the 2803. The 2805 has its input capacitor there, as Vin for the 2805 is Pin-1.
The output capacitor for 2803 is between Pin-5/Diode/LED+ and GND, so it in fact is at the same position as for the MCU capacitor. This Cap might be disposable, one could as well use a higher value for output capacitor (22yF) as the datasheet suggests for “high power” LED - I think they a referring to 750mA.
Any particular reason for PWM using MCU Pin-5? As Pin-6 is the usual rail for pwm in our firmwares and as we’re not using multiple rails on this one we might just stick to pin-6.
I want to do a test setup with a Nanjg 110 and a stripped Nanjg AK47 to see whether the design will work at all.
I have all parts except for the FET. Could someone please give me some specifications for the FET. I have only a faint idea what is needed here as up to now I don’t use FET/DD drivers.
One that I think might fit the pin layout and spec is IRLML0030TRPbF
Power MOSFET
N-Channel
SOT-23-3
UDS 30V
UGS (th) +/-20V
Id 5.3A (4.3A at 70°)
RDS (on) 27mOhm (40mOhm at 4.5V)
That one ok, or any value that could be better than on this one? Or any other value that has to be observed?
Thanks a lot.
