Gearbest Daily Deal Updated: March 16th 2021/ Baseus LED Flashlight $21.99 with the code: GBREAKER
How about another code for package with charger kit and additional 10180 battery?
The coupon code also works for the package deal (D.Q.G.Fairy, charger, and battery) that GB has. Lets you save a little on both the charger and battery.
Mike
No trits though :frowning:
darn it, can’t believe I just did that, I’m in for 2 and accessories…
I went for a Fairy too, first purchase in 2015, have been wanting one since it came out (new years resolution was: no new flashlights before the majority of my BLF-projects are finished, well that went down the drain fast :-( )
Ordered! I’ve been waiting for this for a while now!
Yes it work, I just try it, can choose NW too (pick NW first before link to the package).
Thank you Mike.
Man, what a deal! I paid $35.00 for the original, (with trit), but even without the trit, for $16.99 this is still a super bargain.
I just hope it doesn’t take 41 days like my last Gearbest order did.
What is the mAh rating on a 10180? I saw one on alibaba that said 100mAh…that can’t be right…that light would run what 1/10 an hour or 6 minutes at 1A…good grief!
I'm afraid it is, it is less than half the size of a 10440, so roughly less than half the capacity would be between 100 and 150 mAh. This light runs at 300 mA on high, so about 20 minutes runtime.
BTW, I forgot to include the charger (did not know about it :-( ) so I bought a USB charger on Ebay for a few dollars, changing the sense resistor will make it charge at 100mA (lineair as I understand). WH, is it correct to assume that the dedicated Fairy charger uses the same electronics inside?
http://www.ebay.co.uk/itm/Lithium-lipo-Battery-Charger-module-5V-Mini-USB-1A-Arduino-PI-/181577194527?ssPageName=ADME:L:OC:NL:3160
Do you have the Australian plug versions? I have no interest in adapters. I already own one, and it came with an Aussie plug so Im fairly sure make them that way, although possible the last supplier sourced them separately and switched them in the boxes.
I'll take one with EU adapter. Do you have it?
wonder if there is anyway we can get a discount code on this light
http://www.gearbest.com/led-flashlights/pp_142221.html
Hi Ejected Filament, I’m sorry but we don’t have.
Hi tempo, It will be sent with EU adapter no matter the simple set or the full set, wish you like it.
Is there an updated model coming out soon?
Hi downlinx, sorry to reply late, about the the red flashlight ( http://www.gearbest.com/led-flashlights/pp_142221.html )
coupon: GBSB
price:$21.99
wish you like it :wink:
Not sure for now, but if it comes, GearBest will get it ;), thanks for your supporting.
Thank you very much, i do like it.
