And yes DBCstm it seems shallow for how wide it is but it is fun to try, and while i am waiting to the XHP70 to be available ( please hurry up HANK :* ) i will try it with an MK-R i just received from FT
Working on fine tuning, but I just stuck the XHP70 in an old Solarforce Skyline I. The super deep reflector really gives this bad boy a tight hotspot! :bigsmile:
OH, brace yourselves….The SinkPAD Aluminum DTP MK-R star is $1.00 apiece with a $45.00 minimum. On hand and ready to go. AND, they will have copper MK-R stars by next week or so. $2.50 each at minimum, $75. Price break at 300. The minimum is about 40 stars. Cool beans eh?
The old Skyline I is now making 3046 lumens from 6.68A out of 2 Efest Purple 18350’s. Tighter hot spot than the Olight and far tighter than the X6. Still has a bit of an X in the middle, gonna see if I can dial that out.
This one I put the XHP70 on a 26mm MAXToch copper mcpcb. Cut a groove beside the thermal pad to narrow it down, filled the groove with Arctic Alumina Thermal Adhesive. When the AA dried, I shaved it off with an Xacto for an even smooth surface, then used strips of copper sheet to mount the emitter. The negative wanted to touch ground somewhere and I had to re-flow it, but after that it was fine.
I think I’m going to plan a P60 with it. I was going to do MT-G2, but the XHP50 is comparatively cheap. I’m sure the beam will be hideous, but the overall lumen output should make up for it.
I put the XHP70 on a 32mm Noctigon to go into the Shadow JM26. With the DQG 6A boost driver intended for the Tiny Triple it runs on a single 26650! 2.64A at the battery, looping for the clamp meter from battery negative to ground ring on the driver.
1.5 lumens low
100 med
404 high
1373 Turbo
Now if I can just get that donut hole out of the beam…
Wow, I think this is your third light you have managed to put a xhp70 in! Nice work.
I have heard people turning their reflecters op. Forgot how they did it or what they used. That might do the trick for removing that donut hole…
is there a good source for these XHP’s? i looked a mouser but its 20 euros shipping, a little (a lot) to pricy for me. or if a member is willing to sell me one (to europe), that would be great?
When I tried stippling the reflector I seemed to have gotten carried away. It might surprise y’all to hear that I tend to overdo things. Shocking, but true.
I raised the reflector above the emitter and it’s got a decent beam profile. I did this by putting a silicone o-ring down for the reflector to sit on, then I can tighten or loosen the bezel to squash the o-ring to whatever height I want (to a point) Sitting just above the substrate gives a decent result in this big pretty smooth reflector, there is some garbled bright spots in the hot spot but not an x like before or the nasty dark donut.
Too dang cold for a beamshot but …
I didn’t want to cut on this big nice reflector any more than necessary, so I just notched it for the corners. In the end, I didn’t even have to do that as it would have sat above the substrate anyway. Live and learn.
So, with different reflectors coming as well as an optic, I’ll need to get another XHP70…this one’s found a home.
