is there a good source for these XHP’s? i looked a mouser but its 20 euros shipping, a little (a lot) to pricy for me. or if a member is willing to sell me one (to europe), that would be great?
When I tried stippling the reflector I seemed to have gotten carried away. It might surprise y’all to hear that I tend to overdo things. Shocking, but true.
I raised the reflector above the emitter and it’s got a decent beam profile. I did this by putting a silicone o-ring down for the reflector to sit on, then I can tighten or loosen the bezel to squash the o-ring to whatever height I want (to a point) Sitting just above the substrate gives a decent result in this big pretty smooth reflector, there is some garbled bright spots in the hot spot but not an x like before or the nasty dark donut.
Too dang cold for a beamshot but …
I didn’t want to cut on this big nice reflector any more than necessary, so I just notched it for the corners. In the end, I didn’t even have to do that as it would have sat above the substrate anyway. Live and learn.
So, with different reflectors coming as well as an optic, I’ll need to get another XHP70…this one’s found a home.
For Texans, or anyone who has lived here for a while, it's damned cold! Long lasting cold spells here do lot's of damage and no one is ever prepared for it here. Especially the ice storms.
I haven't gone back to work in the shop since the first 21 degree night and I ain't gonna go in there till it thaws.
I just got the Ledil Iris optic from Mouser. It comes with a black housing and looks like it’s a perfect fit right into an Eagle Eye X6, no modification necessary! With Cree about to get copper MK-R 20mm stars for the XHP70 (this coming week) this is a fantastic way to bump an X6 into the 3000 lumen range. Hot spot is decent, only the very slightest hint of a dark spot in the elusive white wall hunt, and it looks like it was made for this set-up!
Ledil Iris, Cree MK-R 20mm copper star, and the XHP70, perfect combination.
The Ledil Minnie fits with it’s holder using the triple spacer. It’s a nice beam profile as well, maybe even a bit nicer than the optic. But it adds the cost of the spacer or on the other hand it allows more heat sink mass. Win win.
I was born here in Temple, 111º the day I was born and I’ve liked it hot ever since. Me and cold disagree with each other. 36º and raining, with the threat to drop into freezing and have sleet and snow later today. YUCK! Everything will be ice coated and then peppered with sleet. Wrecks all over the place.
I test fitted the Iris into a X6 host. With a 20mm Noctigon sitting on the shelf and the optic removed from the housing it fits perfectly. No lens in the bezel. The oring sits on the optic shelf and the bezel screws down tight. Easy answer for the XHP70 in an X6.
