It was the led that I had at hand, it is what it is. The XH-P50 was again another tint... I think the main message of the test is not the exact outputs, although in any case they are clearly very good, but that there's a good idea about voltages now and (at least for the XH-P50) what the useful drive currents are.
An update for the set-up could be a thermocouple on the thermal junction of the led, like Relic38 did in his amazing copper board tests. It will also make the tests more work (and I am a -let's call it- 'efficient' person ;-) )
Taking cheap shots at poor ol Dale. Y’all should be ashamed. Here I am, trying to help, reading the box and reporting the numbers and I get ridiculed. Guess I can just play with my lights and not tell anyone and let someone else do all the testing, figure it all out.
Rivers of liquid nitrogen in Texas, rich, real rich. You’re invited to come lay in the Texas Sun for 3 hours on August 9th, we’ll have a nice long conversation about cooling.
I’m excited because:
-prices should be cheaper than MT-G2
-can use a normal XM noctigon
-with a Zener driver, I finally have a use for my 2x18650 solarforce.
-should be much less heat than any other comparable output single-emitter, and less work than a triple
Having said that, I’m not familiar with the MK-R, maybe I should look into it.
I’m not a whitewall hunter, a slight donut is meh.
The XHP70 Shadow JM26 with DQG Tiny boost driver at 2.64A, the X6 XHP70 at 3550 and 5.43A, the X6 Triple XP-L V5 2D at over 11A, and the X6 Quad XP-G2 S3 3C…can’t find the sheet lol (10.54A, just checked it again)
Ok I’ll stop now
Awesome to see such varied lights going up against each other, is the JM26 a reflector light or TIR? Interesting tint variation on the hotspot there.
The Shadow JM26 is a lot like an HD2010, but with a side e-switch. It has a big 28mm driver that is regulated. But it only made 900 lumens. The hot spot was gorgeous, very well defined, the reflector in it is unusual in that it is more bowl shaped that parabolic, but it’s perfectly made with no blemishes and no visible machining under the shiny mirror finish. I’m surprised that it is able to focus the array die so well, but it really does a nice job. The inside base of the reflector is about 2.5-3mm above the substrate of the die.
I take a tripod out to the same place every time. I do a quick leveling on it, then use the vertical line of the house to make sure it’s true. Then I zoom in and lock the adjustable head down with the oil drum in the center of focus. Once that’s done, I set the camera for a 2 second timed exposure, manual focus, infinity focus, 1/2 second exposure at f/5.6 and ISO1600 and take wide angle shot and zoomed in shot (24mm and 112mm), then run back in the house before the cold gets to me.
Laughable, I know, but I’ve had an issue with muscle spasms for 15 years that can be triggered by my core temperature falling. Not funny when your body is jacking you around. Bet it looks funny though.
And Paul Harvey says “And now you know…the rest of the story!”
Oh, and I held my breath during the exposure so as to avoid the “smoke” (breath vapor)
Ah thanks, yes that sounds like it’s actually a fair bit out of focus perhaps? I think the quad dies really do like this type of setup best, or else the dreaded donut makes an appearance.
Of course I’m only joshing about the cold, man I’m the worst when it comes to heading out into the cold to take beam shots. I can always find an excuse to stay inside near a toasty test rig and scribble numbers onto graph paper instead.
I’m sure we all really appreciate the effort you put into your beamshots and testing, it’s always a really good and varied shakedown of a new emitter.
Edit: Looking at the emitter pics of the XHP50 above, compared to the XHP70 it looks like the spacing between the dies is actually rather larger on the smaller emitter. Maybe that’s just an optical illusion because of the differences in the dome but those gaps look rather too large to my liking. I guess once they are dedomed we’ll see just how far appart those dies actually are. Could it be worse than the MK-R?
Oh I see! (I think, heh.) Does the spacing look worselarger on an absolute scale, or a relative one? To me it looks as if the inter-die spacing is the same distance for both emitters. It’s just that one emitter has much larger dies than the other, so the relative spacing appears worse on the smaller emitter. Or at least maybe. Eh?
Looking at the bond wires, the gap appears about twice as wide as a bond wire. So it’s really quite small then. The dome is making the die look big, it’s also magnifying the gap between em. We know the bond wires are very thin, so twice the width of a bond wire is what, about .2-.3mm?
It was a simpsons reference, Grandpa said: “The metric system is the tool of the devil, my car gets 40 rods to the hoghead and thats the way i likes it”
I’m shocked i can’t find a youtube video, but here is some more info:
