6V copper DTP XHP70 MCPCB’s, oh boy! I think I might like to get my hands on a couple of those guys, Dale. Let me know when your ready. I think I’ve got just the build in mind.
Will do, they’re $2.50 apiece. I had to meet a minimum $75 order which I was told is 40 boards. She’s sending me some aluminum samples as well as Cu/Al samples for the 50.
Now if I can just find the emitters in stock somewhere…
AND, the XHP50’s will be here end of next month. Oh well, I’ll have something to play with for a little while anyway. lol
Might have to spend some time pulling my rigged XHP70’s out of lights and putting them on the SinkPAD’s. Then I can test all over again and see if there’s any viable difference with the proper pad.
Anybody seen any real leads to the XHP70/50 leds or copper stars for sale at "regular prices and amounts"? Like 2 or 3 or 4, instead of a bunch? Any word from Hank about his stars or Maxtoch about the 26mm ones?
I haven't been keeping track and probably won't be able to for a long while.
I have 40 SinkPAD XHP70 stars coming, they were supposed to have shipped yesterday…so maybe tomorrow? Cost me $2.50 ea. and that’s what I’ll sell em for.
Richard ordered some of these from SinkPAD as well.
Edit: I’ve been snookered yet again! I was told they had a $75 minimum, “about 40 boards” and I was told they’re $2.50 ea. I never actually did that math!!! I should have 30 coming. I don’t need 30, of course, so will be spreading the majority of them out…
It’s not so much that you’d see the donut out there in real life, but you’d see a dark central area as compared to a brighter aura. Messes with the brain, as we’re used to seeing a central hot spot.
Eagle Eye X6 with XHP70 using a Minnie-M Ledil reflector making 4426 lumens at 7.45A
Eagle Eye X6 with MT-G2 using an Iris Ledil Optic making 2500 lumens at 5.43A
These are 35mm optics, you’re asking about 80mm, differences there will be, but you’ll probably have better results from the MT-G2 in an 80mm polished reflector than you will get from the XHP70. This new die needs a special reflector, or at least an orange peel reflector, or optics designed to merge and diffuse the beam profile.
The red 55 gallon drum is 97 yds away…direct middle of the pics.
I was asking about the XHP-50… :~ I’m not going for sheer output, the XHP-50 will still do 3000 lumens otf, at a lower driving current, and my hope is that it would throw a bit better.
Typically, large die are not used for throw. That's why some of the best throwers are using XP-G and smaller dies. I doubt that this XHP50 or 70 will ever be throwers. Usually multiple die leds are used more for floodlights.
And the worries about the 12V vs 6V platform are for naught, as they sent me MK-R copper boards for the 6V set up. No funny business with airwire or resistors or any of that mess.
