And pray tell what does “Porting” mean? Last time I ported anything I bored holes in the end of a .45 Long Colt barrel so the handloads I was feeding it didn’t make the front sight attack me.
In this case, “adapting” would give the correct meaning.
So this would mean writing firmware to utilize the 25 in place of the 13A?
Hel*, I can’t remember what everything is now, why would I want it even more complicated? lol Sad but true…
essentially yes, but “porting” usually implies taking the existing program and just tweaking little parts of it to make it work on different hardware. the overall program will be mostly the same, just little “nuts and bolts” will change. However, with the extra space available on the 25, I would expect the programs to get much more feature-rich (and therefore complicated) once it is ported.
Can the 25 handle my favorite UI: moon, low, high, no memory?
I think a lot of the space issues crop up with features such as:
- Momentary button support. (e-switch)
- Thermal throttling.
- Any use of curves with tables? (fancy ramping)
- Complex UI.
I’m probably forgetting some things, and since I have not been attacking these things myself I don’t know how big a problem features like status LEDs have presented in terms of space.
A production run would be cool, but first we’d need to settle on a “final” design for it. Wight has been improving things almost daily, so it’s not really stable yet.
However, I get the impression that the most popular driver would probably be a 17mm single-sided model with both a FET and a single 7135 chip, OTC, and attiny13a or attiny25. If there’s room, also a pad for a zener. This would cover almost everyone’s needs in the most common size of light — blinding highs, low and efficient lows, off-time or e-switch UI, several popular firmwares, and easy to reflash. Not much room for solder stars though, so people would need to mostly agree on a default firmware.
He also made a pretty amazing 15mm model with everything above except a zener, which I’m hoping to try soon in some 1x14500 lights.
Hey you asked
Original ATtiny13A > ported over > ATtiny25A
Porting also means heavy set guy….er…no that’s portly, sorry I was thinking of myself
Hey look at that! I was spot-on without looking it up 8)
and then some
If the ATtiny13 can do all that…imagine what the coders could do with 2X the space…think “dual group modes” and whatnot
yup yup
I make a good living off of porting code - that's what I seem to do most of the time, lately, for the last few years... We went from custom embedded hardware (1st generation) in ASM/C/C++, to COTS (Commercial Off The Shelf) boards w/custom plug-in hardware (2nd generation) Win CE based in C++, and now (3rd generation) to Windows based Panel and table PC's in C#/.NET . Maybe 150k-200k LOC's (Lines of Code) ported along the way...
Ho, ho, ho, off to port code we go...
I’m glad I haven’t had to port code very much. Occasionally fix bit depth or endian issues, yes. But mostly I get to use Python and shell, which makes all that moot. Before attiny firmware, I think the last time I had used C was in the 90s. But I like C, it’s still one of my favorite languages. I’d probably like Go too, but I haven’t really used it yet.
Most of the code I write is basically prototyping anyway. Proofs of concept to decide on a good design or test potential solutions, and then if it turns into important infrastructure someone else can maintain it. Or little bits of code to break things. Or anything which satisfies the rule of three — the third time I have to do something nontrivial, I automate it.
I built a BLF17DD from Mountain Electronics. It didn’t work. Positive and negative in were shorted together. I saw a line across the positive LED pad and scratched it out with my camel bone handled pocket knife, which fixed it.
Looks like a bit of extra solder may have squeezed thru that via and accidentally bridged on the ground ring
I’ve used that same board from OSHPark a couple of hundred times, never saw anything like that happen.
Ya cuz a knife with a plastic handle never would have worked.
LOL> Sorry, I just couldn't resist. Glad you got it fixed man.
In the most dignified way possible: SQUEEE!!!
Using a hot air station makes it so much easier to assemble
