Ultrafire F13 at $11.39 - with Coupon Code - Gearbest
The writing on stars should never be trusted. Most of us ignore it as a point.
As long as you’re in there soldering stuff, you may as well remove the star and add some thermal grease under it if there isn’t any there already.
Thanks for the pic, looks like a nice solid shelf. Although the anodizing on the shelf isn’t great.
Look forward to getting mine.
They are good lights right off the shelf and better when they have a good copper star and a nicer driver put in. 5 amps is not unreasonable, since they transfer heat well. Glad y'all are having fun with them.
That’s strange… Got mine today too. But on the outside it says “XML-T6” - and that’s what’s inside - so it seems. It is only an older XML with green top, 3 bond wires and 6 stripes. On a grey star with no other text than +/- signs on it. Let’s see what the customer service has to say about that…
  • 1 From the Deal Alert thread.
    Nice build for the price. It won’t quite lock out by unscrewing the tail cap after some wear, because some aluminum shows through the anodizing on the threads. I have not opened it up.
Anyone stuck an MTG2 in one of these? I’m thinking of picking a few up.
The new XHP70 and XHP50 might not work too well with this reflector.
I have to delete all my book marks to this site. Old-Lumens you just forced to buy my 6th light this month :open_mouth: :open_mouth:
I have read these forums for a while but never really paid attention to the “deals” now I’m like sweet its under $20 I can get that one. Well buying 6 lights under $20 doesn’t save me money :confused: AHHHHHHHHHHHHHHHHHHH I need help.
I’m tempted to buy another one of these,the only thing holding me back is the first one I got from a earlier GB. The tail cap is very loose on the threads, it wobbles side to side when screwing on and the threads don’t look like they will last long. Is this normal for the F13 or did I just get a bad example?
Now that you mention it I did note mine being a bit loose as well. The tolerances could have been a little better, certainly. Once tightened up it’s rock solid though. Given the high number of threads on there I can’t see it being much of an issue anyway, as they’re not under any great strain.
Yup, it’s on the ‘to do’ list, thanks. Dry as a bone under there, as expected.
I’m thinking customer service will tell you that they sourced these leds by sweeping up an old flashlight factory floor. Anything that end up in the bin at the end of the day wandered it’s way into these lights :wink:
These leds are almost always terrible bins and need to be replaced so I wouldn’t worry too much about whether it’s a gen1 or gen2.
Just get a nice XML2 on copper and swap it over, it will cost almost half the price of whole light but it’s worth it. :slight_smile:
used the little store points i had and got this for $7 shipped :)
For a while early on they were shipping bodies engraved with the old T6 logo, even after they started putting XM-L2 emitters in (very blue-white, as noted worth replacing anyhow).
They must have found another freight car full of the old ones somewhere, or a new cloner has started making copies of them.
Watch for the typical “new batch cheaper and worse than the last” progression — since this light has become popular, it’s likely being cloned.
I hope not all of China’s manufacturing follows this same progression.
If they do the same thing with parts for their railroads, aircraft, and power plants — especially all those new nukes — the world’s gonna have troubles.
And they’ll blame you, Old Lumens, when their country collapses. You! You made them do this to themselves ….
The tail cap threads on mine fit better than those on most of my lights. I understand that the precision of numerical control machining is mainly limited by thermal expansion, so it gets worse as the process is sped up.
This light was already heavily cloned. (eg what we are discussing here was never the original)
This doesn’t mean that cheaper clones can’t be made but generally the process seems to bottom out. (like with the SRK) I think the F13 lights probably bottomed out a while ago.
I wrapped duct tape, textile, around the thread, it works, it is smooth and accurate.
Get some good silicon gel lubricant and put it on the threads and o-ring…goes a long way in making it smooth screwing it in
I use duct tape on my two Yezl t9s, because they have intermittent tail switches for electronic switch drivers, but now have regular drivers. The threads are anodized but not completely. It works nicely but eventually starts getting loose. Aluminum foil epoxied on lasts longer. I have some thin copper but haven’t tried it yet. I have a couple of very cheap SK-68s that I have junked because of the tail threads.
Thanks O.L., ordered one for my DST build.Hopefully, the threads are good and don’t wobble too much.
DST? (I’m only familiar with that in the context of the Defiant Super Thrower.)
