I had to run to the local HD today (which usually isn’t great) to grab some flat steel to fix my jeep’s seat. While I was there I came across a light fixture that I knew had been marked with a .03. It was unpriced and buried in the clearance section.
Sure enough it rang up for a penny. So if you see these in your store, grab them.
XJ, I have never noticed those, I will be on the lookout.
On the same note, here is a score of an oldie but goodie that was mixed in with the current stock. The cheaper worklight that has gone from full list to 3.04 to 1.52 to .01. It looks a lot like the current worklight that HD has that sells for $11.47. Here is one I found in a box of the others. I can recognize it as is not fully enveloped in a clear acrylic package.
Side by side with it’s replacement. Rang up for a penny.
Here’s a couple of other things I spotted. Recently, 01/01/15, JonnyC posted about the High CRI Bulbs at 6.50 and 7.50
Well the other day I noticed that they have been reduced another 4 cents. What’s important about that is that this means that they are now on the reduction spiral, their priced and amounts that end in “6”
With a date of 11/19/2014, it will be a long time before we see a lower price that ends with the “3”
Here’s 2 items that should go to a penny any day now. With dates of 07/03/2014. Even though the remotes are priced at 15.06, right now they will ring up at 5.03. The store is definitely not on the ball on this item. I figure this will go to a penny on or about 01/23/2014
^ That Phillips light just the left of the camera and above your hand. Got one of those for a penny a month or so ago. It's a remote phosphor type light and puts out a pretty pleasant tint and even light.
Well then, looks like I need to take one up to scan! It could be that I missed one. Actually I’ve seen those many times before but I never knew they were cleared out, nor have I ever checked the price
I struck out again on penny deals in D.C. while we were there, but I did get this 70piece screw driver set for $2.52.
Before our trip I got these 2 deals locally.
The 28 piece combination wrench set was $12 abd goes from 1/4 inch to 3/4 inch, 6mm to 18mm
Also included in “stubby” lengths is 3/8 to 5/8 and 10mm to 15mm. This same wrench set was offered last year and eventually was reduced down to $12 at the very end.
The twin 100 pack of Stanley blades, Made in the U.S.A., total of 200 blades was only $5. I happened about those as I was in the store carrying the wrench set. A store employee came up to me a told me they see me in there all the time and would I be interested in them. I said sure and he went overhead to bring them down. I bought all 7 packs. I am spreading them around to friends etc. Also I plan on rounding up all my knives and filling them up too. (I probably have 25 of them in use). I always have 3 or 4 within arms length, because when a blade goes dull it’s easier to just grab another knife. I periodically go around and change all the blades at the same time.
Those are some great deals in you last couple or so posts dchomak. Hoping to find a couple of them next time I hit a HD. Would like to find that light xjsnake scored too.
Update to my last post. I hit two other HD’s today within 10 miles of where I got the light fixture. The exact same fixture is sitting on the shelf at @ $29!
So at both stores I went up to see if perhaps I’d struck gold and the fixture rang up at $29.
Just goes to show how individual some of these deals are to certain stores and how general others are across stores.
Are you sure it was the same EXACT light? Sometimes there are slight variations to color or finish of an item and one will be cleared out, the other not.
I did have that same experience with that parchment globe awhile back though.
ImA4, I checked out that bulb you mentioned. My local has plenty of that type bulb but they are not a penny. Maybe yours is different? Or maybe this is another example of what XJ is pointing out?
^ Everything on the front cover looks the same in every detail. My discount tag is $23.06 with date of 4/15/14..
Bar code on the bottom of the package. Text above it is:
3241 642 18371
PROOF OF PURCHASE
BC17A21/AMB/2700 DIM 120V
Number below bar code is:
0 4667 42222 6
This happens sometimes. Many of the penny and great deals posted here are still full price items when I get to one of my local stores. Usually, the items are just not there to be found.
For some reason these 106 quart storage containers ring up at 2 different prices. Although they are identical in every way except for the lid color, the blue runs ring up for $4.54 while the white ones are $15.47. It’s not the lid that goes with the container that sets the price, it’s the sticker on the side of the container.
After searching the stock in 2 local stores I was able to find 7 of the “Blue Tops”
There were only 5 blue lids, but that’s OK, I just grabbed 2 of the whites. Remember it’s the sticker on the container that sets the price.
And why would I NEED 7 106 quart storage containers, other than to store all the other crap I get from HD?
Almost any other brand of 18V drill pack battery costs a least $100 for a single pack. An 18V pack uses 5 18650’s to reach 18V (21V). A double pack uses 10 cells in a 5S2P configuration. At the start of the Black Friday sales, Ryobi came out with a 4Ah pack and the deal was buy one for $99 and get a second pack for free. That was quite a deal at the time. I bought one of those then and sold off 1 of the 2 packs to a friend and gave the second one to a neighbor friend who looks after our house when we are away.
Since that time I have watched that deal go from $99 to $89 to $84 and now to $75! The HD’s I have been in still have cases of these batteries. 2 packs of 10 cells each is 20 cells and at just $75 that works out to only $3.75 a cell if one were to harvest them. All other Ryobi packs that I have taken apart recently have Samsung cells, I am thinking these probably have the 20R’s in them.
As of 01/09/2015 these batteries on the clearance spiral. Next price reduction will end with a “6”. When that will be I can’t guess. They probably won’t last that long, this is a hot price as is.
I was in HD this morning and ran into the guy that changes the prices. He saw my cart full of Christmas tree stands that I had picked up at the front entrance at $1 each and asked if I had seen Gerber Tool. I had, they were marked down from $20 to $5. He told me that he had one and the manager of the store bought one also at that price. Since I know nothing of knives I had passed, but based on what he said and the fact that the manager bought one I picked one up.
Here are the Christmas tree stands, I will try using them for patio umbrella stands next spring. Not quite what they are intended for, but those patio umbrella stands are usually $30! For $1 what have I got to loose, besides the 5 eye hooks that come with it worth several dollars by themselves
Air tool connectors, and gauge and parts, heck the plastic case alone is worth $2.
Also 3- 50’ air hose for $5
That is 3 separate 50’ air hoses for $5!
Once again, to be clear, this is a pack of 3, 50’ air hoses for $5.
dchomak, I’ve gotta start shopping at your store. I was tempted by the hoses at $20. $5 is ridiculous. And the air accessory kit for nearly nothing is sweet too.
Man, those are some good deals. All of the items in your last 2 posts are still full price at my HD's. I'll be keeping an eye out though. Thanks for the alerts.
