I put both, an MT-G2 and SST-90 in one of these, I didn’t like the beam of either emitter with this reflector, they both had artifacts that I couldn’t get rid of and the stainless steel bezel creates a ring in the outer portion of the beam that I didn’t like.
IIRC with an XM-L2 the hotspot was quite large when I swapped the stock centering ring for a ‘normal’ thin/winged one. Before that I think maybe it was not very good? Ringy or something? I don’t recall. I do wonder a little what the XHP50 would do.
I ordered one on 1/17 and received it today. What!? I checked my account and it turns out I had ordered one on 1/3. So it took 17 days to get here and not 3.
The tail cap is fine on my sample. I did have to grease all the threads. The light is pretty much as Old Lumens reviewed.
Now I just need to assemble a BLF17DD driver and flash a custom firmware and I’ll have a true budget light.
Thanks WarHawk-AVG. I wasn’t trying to steer dthoang away from the BLF22DD, I just noticed the specific mention of the BLF17DD. I figured I’d mention the size consideration to try and prevent tears.
I’ve been thinking that I should do some new 22mm boards. There have been plenty of interesting developments since the last 22mm boards were done.
EDIT: Your post is maybe a little confusing to those who don’t know. Why don’t you put the hyperlink to the BLF22DD on the BLF22DD text instead of the BLF17DD text? :~
Yes, it took some days but it seems that I will get a refund. I’ve ordered another one in between and was assured that the current model will be shipped. Let’s see what I will get this time…
Today I’ve got 3 XM-L’s from FastTech which I was planning to use for replacements (mounted on 20mm stars because I’m not in the reflowing business yet). Although only two of them should be XM-L2 according to my order, I’ve got all 3 as XM-L2 with silverish top (all T6 bin with 1A/1C/3B tint). Let’s see what I can do with them.
I received mine today also, and it too has XML-T6 stamped on the side and thats what is inside (no thermal paste at all just loose on top of shelf) Driver is slightly different than what has been posted, a YN-22-T6 different position of some components.
Gearbest customer service are quick in replying , I emailed them yesterday and today they replied offering replacement or refund , I asked for replacement as long as it has XML2, the XML I have is not that bright and has a lot of blue tint in it.
This batch is worse quality than the first batch. Very poor, even at the price point.
Sorry, I just can't know for sure what we will get any more and it seems to get worse every time. Even if I ask for a sample first, I don't know if that sample will be representative of the actual lights going out.
Mine came in. Ordered on 1/7/15. Has an XM-L2 in it, says XM-L2 on body. Threads are loose, but I plan on putting Teflon tape on them anyway and they improved with lube.
Mine arrived today. I’d say it’s not bad for the money (as a cheap host)
Pros:
-Nice chunky body and love the plentiful heatsink fins. This could definitely be a nice little hotrod light.
-Reflector & lens nice and clean. Came with a protective plastic sheet over the glass which is nice.
-Decent external condition, some cloudy anodizing on the head and a few dings on the aluminium bezel.
-I like the red tailcap boot. Something a little different
Cons:
-Mushy crappy tailcap switch
-XM-L T6 on body and XML inside. Pretty blue, maybe a 1C. Might be ok once I’ve fixed that crappy centering ring and brought things into better focus.
-Very tight driver retainer. Tweezers where a complete no go here, had to break out the needle nose pliers to break the seal.
-Craptastic driver, seems to do Med, Med, Slightly-lower-Med, Flashy, SOS. So it’s really only fit for the bin.
-Fairly loose tailcap threads as others have said. But the anodized threads are pretty clean and the O-ring is correctly sized so it makes a better impression once you start to tighten it down. Should be ok if you are careful not to cross thread it.
Mine had an okay tint, but I don’t have many lights to compare it against. I’ll fix the centering ring and I’ll figure out if it has a green tint. Comparing it against a nichia 219A tells me that it is a CW LED with a bit of green from the GITD O ring. The surface of the light isn’t aggressive enough for my liking, it make it hard to push the tail cap switch.
Mine also arrived today, also with a gen 1 XM-L. However, I don’t care much about the emitter because the battery tube is going straight to my DST anyways. The giant “XML - T6” on the side is annoying though, is there any way to get that off?
