M4D M4X ,I appreciate you getting codes you have saved me about $50 this month.(which I guess means I buy to much) I look at it as BG paying you a sales commission, cause most likely I would have bought from another site or not got them at all. If members donāt like what you do I donāt know why the bother reading your posts.
Can you find out which of the three available tints this one is?
probably CW (but not blueish)
mhanlen sent me one that was ābrickedā I was able get it running (again thank you).
Here is what I think, I love the fact that in two clicks I can get the full range from maybe 10-30 lumes up to the rated 450 (which for a head lamp is a lot). No observed PWM no humming.
The ramping feature is so smart. click it once and it comes on in high and while holding it, it will slowly cycle āhiā through the whole āhiā range, lift a finger and that brightness is memorized. Click a second time and you are in ālowā (same deal) Bingo you have two prefered levels memorized. double click, strobe, double click again and SOS. Click once more and back to ānormalā
It is light weight, the band is a bit snug for āEinstein headsā, think of it as āsecure ā Maybe when the elsatic streches a bit it will be just right.
FYI for thoes of us who like to mod. The head is pressfit over the (glass,reflector,emitter and pill) in such a way that I have not figured out how to get into it . The head unscrews easily and access to both sides the board and teeny tiny wires is right there, the switch wires are tucked up in a hard to access recess (havent figured out how to get the switch out). So on a moding scale this on is a mechanical challange.
The battery comparment is long, if you pull the plain spring out it measures 75.5mm so if one wanted I am sure two 18350 cells would fit with rooom to spare, add a small spring and bobs your uncle. (just in case you were thinking about a 6V mod ).
I belive it is an electronic switch (every time you repace the battery expect the light to come on and to need to reset your light levels)
I get that you were being sensitive to some criticism (deserved or not) about links.
But consider that if you donāt post (your) link in (your) thread it means that we and you need to go through additional separate PMās to get your link.
If you are going to post the price with the code put your link up and we will be done with it.
I thought you were going to post two links and we would pick one (I say just post your link) and if we want to use the code directly, then folks will take care of that them selves.
So a long version of āthanks youā, yes please send me a link to the ch10 or better yet just post it in this thread.
@Ronin42:
i wanted to do that with the update yesterday - but somehow i lost the complete post twiceā¦
i will try to fix that asap
(but since last week i have a lot of work in a hospital (~12 hours a day) and a baby growing teeth - just a little time for the forum
Thank you, M4D M4X. FDDNCR works now.
This code saves 9% vs. the 8% BLF code saving but only if buying 1 pair. With each additional pair you buy in the same transaction, the value of the FDDNCR code decreases. If you buy 3 pairs only, BLF code already saves more than FDDNCR code.
I remember seeing best prices for protected NCR18650B in the $15 - $16 range for a pair within the last year. Perhaps, it was a group buy? You wouldnāt be able to find something comparable, perhaps a group buy, would you? Bangood would sell 100 of these batteries with your 9% coupon for $16.63 already. Perhaps, BLF members could purchase several hundred with 10-12% code which should bring the price well under $16.
As the Japanese yen has declined against the US dollar and most other world currencies due to Abenomics in 2014, the purchasing power of US dollar has increased which makes it cheaper for Bangood and other vendors to buy Japanese products. Therefore, such stores could offer better discounts on Japanese-made (not Chinese-made) goods now. You could use the strength of US dollar against the Japanese yen argument to negotiate with vendors regarding discounts for made-in-Japan products
I would love to see BLF members benefit from the growing purchasing power of US dollar and not only stores who purchase Japanese goods and resell them in US dollars.
