Yes it work, I just try it, can choose NW too (pick NW first before link to the package).
Thank you Mike.
Man, what a deal! I paid $35.00 for the original, (with trit), but even without the trit, for $16.99 this is still a super bargain.
I just hope it doesn’t take 41 days like my last Gearbest order did.
What is the mAh rating on a 10180? I saw one on alibaba that said 100mAh…that can’t be right…that light would run what 1/10 an hour or 6 minutes at 1A…good grief!
I'm afraid it is, it is less than half the size of a 10440, so roughly less than half the capacity would be between 100 and 150 mAh. This light runs at 300 mA on high, so about 20 minutes runtime.
BTW, I forgot to include the charger (did not know about it :-( ) so I bought a USB charger on Ebay for a few dollars, changing the sense resistor will make it charge at 100mA (lineair as I understand). WH, is it correct to assume that the dedicated Fairy charger uses the same electronics inside?
Do you have the Australian plug versions? I have no interest in adapters. I already own one, and it came with an Aussie plug so Im fairly sure make them that way, although possible the last supplier sourced them separately and switched them in the boxes.
I'll take one with EU adapter. Do you have it?
wonder if there is anyway we can get a discount code on this light
http://www.gearbest.com/led-flashlights/pp_142221.html
Hi Ejected Filament, I’m sorry but we don’t have.
Hi tempo, It will be sent with EU adapter no matter the simple set or the full set, wish you like it.
Is there an updated model coming out soon?
Hi downlinx, sorry to reply late, about the the red flashlight ( http://www.gearbest.com/led-flashlights/pp_142221.html )
coupon: GBSB
price:$21.99
wish you like it
Not sure for now, but if it comes, GearBest will get it ;), thanks for your supporting.
Thank you very much, i do like it.
hello,
GBDQG coupon for the dqg neutral white clicky is not working anymore, would it be possible to make it work again ?
I already have 2 twisty, i need the clicky one…
Thank you !
hello,
Thank you !
Hi Patrickbateman, I’m sorry but we can’t extend it , the DQG raise our price and find this coupon, don’t allow us to extend it.
I received my DQG Fairy on the special deal the other day. My last two orders both took over 40 days to Norther Calif. This one only took 20 days from ordering to receiving! They also notified me when they shipped it and even included a picture of the packaged light like Fasttech used to do. Good job GearBest! You’re getting GearBETTER! :bigsmile:
As an aside, the light is great but the white O-ring that it came with was a little too large and it took both hands and quite a bit of effort to turn it and off. Luckily I had some extra black O-rings for the Fairy and Spy I had ordered from CNQG awhile back. I installed one and lubed the threads, (they came dry), and it now operates smooth as silk even with one hand.
Hi how do I ad the EU plug to my order?
Xtar VP2 Charger - Full set
My suggestion is to contact them and ask if they may have the eu plug adapter for VP2.
Or if not, you add to your cart something like this http://www.gearbest.com/cables-adapter/pp_84264.html
