I have one on the way!
I paid only 3$ and a few cents bcos I used a giftcard…
When I ordered it was 6.12…
now it is 4.42$… without giftcard or coupon… XP
I will update once receiving it…
The reviews says only good things about it…
Interesting...
I think a couple of these with a power bank and USB splitter might be useful for macro photos... Flood beam from two different angles should help illuminate and eliminate shadows.
But its only ON/OFF no power adjusting so I will wait until they add that…
Nice light. Is the stem flexible so the head can be turned 90 degrees from the usb plug?
It is flexible…. look the photos…
Yes but only down. Can the head be turned 90 degrees to the usb plug itself?
I dont know XP
I received one last week.
I’m very satisfied with it, nice light to have.
I also received XTAR UL1 usb light, similar to Xiaomi, but with more options and with flexible metal hose/extender.
One of the largest sources of informations -> youtube https://www.youtube.com/results?search_query=Xiaomi+USB+LED+light
Thanks! hpe to receive mine soon
The bending portion is quite flexible, and can be bent up and down. It can be turned slightly sideways but not exactly 90 degrees.
Thanks 567.
Watch out for the fake ones. I am still waiting to buy from their official store.
Ordered from Banggood. Thanks!
Not sure how to check fake or not fake. But the one I have seems real; at least it lights up! and the quality feels rather good.
had one on order from fasttech along with their power bank, Xiaomi has it going on.
I bought an “original Xiaomi” from Aliexpress.
No “MI” marking as in advert and no ON/OFF switch?
mine is genuine from dx… has retail xiaomi package… mi logo over the plastic part of the usb and no switch of course
it has something electronic control inside…
if you plug it to a usb port it lights up… then if you disconnect it and connect again IT WILL NOT power on… you must unplug and plug again to switch it on… thats the normal behviour on genuine ones
Actually I meant that you can either plug it to work or unplug it and it is off, no power level (light intensity) adjustment like with those small noname usb lights with touch sensitive back…
Bought another light from Banggood and this turns out to be genuine.
Brighter,better tint and on/off works as it should and as Sirius9 says.
