Thanks, but I didn’t find those Nanjg springs. They’re smaller than the ones you linked too. Sure I could cut ’em up, but would prefer not to have to do that.
How about a brass pillar the size of the spring? The spring does not compress much anyway and the pillar has a lot less resistance (and looks better :-) )
Yeah, I’ve thought about that… would work… but thought I’d first ask if anyone knows if I can get the springs. Would be the easiest solution as it’s not just with one or two lights I’ll be doing this.
I have also been unable to find them. I’ve looked several times. Recently I thought that I remembered finding them in the past, but could not remember where. It was probably a false memory.
Yeah, gone through all the usual suspects.
I could send you 8 or so if that would help at all?
I never use them.
I’d gladly accept them! I’ll pm over my address.
I’ve never been able to find them on their own but one day I was able to purchase 40 of them from RMM here (that he pulled off and saved up), maybe you can get on that notification list or just ask him directly. I would offer some of mine but that was a while ago and I’ve went threw them…
If you find an actual source please post it, I need more too!
you can count on 3pc from me. I always saved them knowing a day would come when they’d again have purpose
If everyone on here donated their unused nanjg springs I’m sure you could fill a bathtub with the things!
IO has some springs:
http://intl-outdoor.com/goldsilver-plated-springs-for-drivers-and-switches-5-pcs-p-325.html
http://intl-outdoor.com/gold-plated-beryllium-copper-spring-5-pcs-p-831.html
I have the same problem, the IO springs are too big in base diameter (except the very small one which is only 2.5mm high - might be insufficient, will try).
Ill have to find a few of these springs too!
The “F” spring is a bit short but might work in conjunction with a pillar.
Qlite spring from MtnE.
Edit- note that these are longer than springs sold on most other 105 C drivers.
Cool! Your MCUs will be in my hands tomorrow, got the slip today.
I’ve got some of those F springs on the way already. Will see how useful they can be, but appear slightly wider.
Longer doesn’t matter, as long as they’re not wider. They’re out of stock so I’ve entered my email address under “notify me”. Thanks for the tip.
These springs might actually be the closest thing yet. Going to order some and find out. Thanks for the tip.
I’ve got a few. Probably 10-20 or so. If I can find them they are yours.
Just pm me your address and I’ll send them out tomorrow after I gather them up.
Thanks for the offer! PM sent, will of coarse pay for postage.
