BLF LED Database - Collaboration Spreadsheet - Share latest news about where to buy LEDs
I could use some help with google spreadsheets. I’m looking to add a note across multiple columns.
This can be found on the MCPCB page line 3 & 4 “XM boards are compatible with: XM-L, XM-L2”
I think a comment like that would be good on the nichia 219 page. Something like “Type: 219 A = NVSL 219AT-H1 , 219 B = NVSL 219B R85” The comment column could then be decluttered.
Thanks for info djozz. I ordered some various emitters again. Including red XP-E2. 2amp here I come.. Edit: Around 2,5amp here I come.
Thank Helis for adding emitters. I added a few too.
Helios-Evil-Twin. I divided the Nichia sheet into two sheets. One for 219A and one for 219B. I think that makes it easier. Good enough?
Thanks to Helios or whoever it was who made it easy to sort between the two.
I looked at the spreadsheet and was going to clean up some things to my own taste but reconsidered. I think you should start using abbreviations and symbols where necessary. EG
-Yes can be Y
-Free shipping = Y, Not free = N, Not free but cheap = N, $, Not free expensive = N, $$
-A lot of repetitive words are unnecessary. Sinkpad = SP, quantity discount = QD,
-Could move “edited by” to last column out of site, almost unnecessary but if you want to keep it then general users won’t need to see it. SAme goes with “updated”
-Should standardize number separators. The Europeans are using the comma and the Americans are using the decimal
And a few other things that would help it be cleaner. But thats up to you guys!
Finally a source for the 4000K MT-G2, new at intl-outdoor, bare and on 20mm Noctigon:
http://intl-outdoor.com/cree-mtg2-m0-4000k-2step-6v-bare-led-p-801.html
..and XP-L at IS, 2A, 2C, 2D tint
Added them (XP-L's from IS) to the spreadsheet. Got mine in like 2 days. They must have them in stock here in the USA.
found MT-G2 4000K at newestrend.com for 14 dollars. They claim the bin to be P0 (the highest MT-G2 bin), but according to the Cree datasheet the 4000K led does not come in P0. Would the 4000K be true?
http://www.newestrend.com/cree-mtg2-p0-2step-4000k-led-6v-1-piece-p-1122.html
Not sure if its worth the gamble on the one from newstrend. Barely cheaper than from IOS, and who knows what you will get.
Anyone asked IOS about CRI on their 4000K MT-G2?
Standard CRI, or 80 CRI??
Anyone besides me using either regular amber or PC amber?
If so I’ll add the sources I know, but I don’t know much.
It appears someone using the xml2 tab has turned off the filters and then sorted the header row into the data rows. If I get a chance, I will try to fix it but hopefully whoever did will because only they would know what else they may have changed.
any sources for xp-g2 s3 1a ?
Intl-outdoor has my all time favorite colour temp XM-L2 (~3700K) now in a even better tint : T4 6A2 80CRI.
I have 6A1 80CRI's in various lights, and they are great but just a bit too rosy, I kind of like that but I think that this 6A2 is just a bit more neutral tinted.
I really liked the 6A3 (T4 80+ CRI) that I picked up over a year ago. A very nice WW emitter. 6A2 should be really nice as well! :) 6A1 was too rosy for me, but I found it great for tint mixing when there was a need to boost pink/red.
I see IOS have gotten XM-L2 U2 3C in stock now. (And XP-L V6 3D, in case anyone missed it when Hank announced it).
The spreadsheet is and have been a mess most of this year. Too much work for me to keep up to date and fix. I still think its nice to have this thread for simple updates on where to buy certain emitters and such. :)
I added the XHP section awhile ago if you haven't seen it yet.
https://docs.google.com/spreadsheets/d/1h_pJdXsLdFrrfAUMdMoq5ltGLfQ6Aq-giJ_CbHT3xio/pubhtml?gid=1076526472&single=true
Just added the XHP70 5000k N4 bin 3C tint from Cutter Electronics to the data base.
XM-L2 U4 needs to be added.
A lot of offers from intl. outdoor are missing. Added triple Nichia, feel free to add XP-L and other missing LEDs.
Finally a XP-E2 in neutral available and in R4 bin!, intl-outdoor has a R4 3C, on 16 and 20mm Noctigon.
(I'm not so much into updating the database, but I did want to mention it here)
Added XP-L HI options
Updated Nichia 219b (they now come in a V1 variant with R9050 chromaticity/93 typical CRI rather than the older R85 chromaticity/92 typical CRI)
