Not with any confidence, but I bought two anyway if that helps. Its Panasonic, and Eneloop branded (though I have no idea why), how bad can it be? It seems to know what state of charge the li ion is so it must have some smart features in it.
Edit: Its taking a while to charge though using the supplied cable and head (plugged into a USB3 port on my PC). Been going about 3 hours and the light is orange. However reading between the lines of the manual/specs, it might do better with another cable to recharge itself with. The wording seems to indicate the cable is limited to 0.50a. Its not a unsurrmountable issue if Im right, the cable is just a USB to Micro cable anyway. Ill try to charge the other one with a USB cable I have here I know is rated for at least 1.0a.
I got both boosters delivered now. They are solid. Well worth the $10. First attempt at trying to crack one open, it is sealed pretty well. Damaged the corner trying to get a wedge in. Not sure if I’m going to keep trying as I do like it. It is on par with sealed laptop battery packs in terms of being glued tight.
I put it on Qi charging pad and voila! It charges!
I’ve tried charging a phone and charging the booster at the same time. The wall charger is only rated for 1.2 A max, infact it is the charger for a N900, which I’m charging at the other end from the booster and it pulls 500mA during a charge (edit, the N900 reports that it is a wall charger so max rate). I don’t know what the booster is doing when it is plugged into the wall and charging another device but the green light turned to a yellow light during the process. I think when you have it plugged into charge another device, the booster stops charging from the wall
will play around with it more but it makes me want to look for a good USB light, maybe the xtar u1
Damn, do I or don’t I? The two I have are great I have to admit. One permanently has an Ikea USB light on it and is used as a bedside light, the other, I’ve used it it once to top up my phone.
…both are online only deals so you cant buy at these prices in store but you can click and collect in store if one is handy to you, saves the delivery cost. These deals usually end at midnight, unless they sell out earlier.
Eneloop Pros under $15
www.dicksmith.com.au/eneloop-pro-rechargable-aa-4pk-dsau-pw8009
Bahco 2444 Knife (made in Sweeden by Mora) - $16.90
on eBay
on YouTube
Hultafors Heavy Duty GK Knife (made in Sweeden) - $15.04
on eBay
on YouTube
Bahco 2449 Curved “Wrecking” Knife - $39.02
on eBay
on YouTube
The Bahco 2444 is the only exclusive Australian knife posted but the 2449 and Hultafors are as cheap as I’ve seen available in Australia.
I’ve owned the Hultafors Heavy Duty knife for a long time and its my favourite work knife since.
The Bahco 2444 is made by Mora in Sweden, the 2449 is made in Taiwan but all Bahco tools have a lifetime warranty. The wrecking knife states on the packaging you can use a hammer to hit the spine to cut into things. Also interestingly Snap-On owns Bahco and the knives come in “Snap-On Industrial Tools” packaging.
I have purchased the 2444 and 2449 but they haven’t arrived yet.
It's $5. I haven't got one myself, but it doesn't look too bad. Plus, it's powered by easy to find AA cells. The only downside is that I can't pick them up. Delivery cost (tried 2 of them at checkout) was $7.95. For me, it seems that ordering 5 maxes the delivery cost to $11.95.
The 2444 is available here in NZ at Bunnings among others for as little as $8. I believe they are a rebranded Mora Companion F. Great knifes for the price.
Woolies has 4 packs of Energizer Lithium AA and AAA for $15. Usually $21, and I rarely find these on sale anywhere. Sale likely ends tomorrow (Tuesday) as new sales usually come out on Wednesdays.
