Solarforce L2 Sand Classic CR123A Flashlight Body @ 8.99
From Solarforce sales FB page:
Limited stock & Discontinued version~ Once it is sold out will not be available again!
Solarforce L2 Sand Classic CR123A Flashlight Body @ $8.99
Link
Where is the differnece between this one and the L2 18650? Same size, same diameter, some weight?
This must be the pre-2009 model L2 that does not accept 18650's.
- Uses both primary (CR123A) lithium or rechargeable li-ion (CR123A x 2 pc ) batteries (not included)
This body WILL NOT FIT 18650 battery
- Input voltage available (LED module): 4.2-8.4V, 3-6v or 3-18V
- Input voltage available (Xenon bulb module): 6V, 7.4V, 9V, 12V or 14V
- Length x diameter (head and battery tube, mm): 146 x 32 x 25
If you happen to like more matte feel, get this.
I have L2i in sand and I like it far more than shiny black L2.
Thank you for the information. I ask solar-force on facebook and the wrote me the same: The Classic one is the first design model of L2~ it can only use CR123A x 2 pc to run it, (cannot use 18650).
You might use 17670 batteries in it.
17670 is inferior to 18650.
This body is $8.99, pay $2.51 more and you get to use 18650.
solarforce-sales.com $11.5
