[Mod] Convoy S2+, plus...
The little Convoy S series has become pretty popular. I already have a couple of S2+ triples with DD drivers, and a nice little S2 Nichia 219b that I currently have on the bed-side table.
There’s been a few times now during the night, where I’ve needed to use the little S2 bedside torch, & wished I had the flexibility of an e-switch firmware.
Moonlight for the toilet run? Turbo for the ‘bump in the night’? One press, no mode-cycling…. sounds great, but just not with the S2
…Or maybe I could…
I had another S2+ on order, along with a ticket in the KD Nichia lottery. Whilst waiting for it to arrive, I thought about how I might fit an e-switch to it…. Here is how it panned out;
Being a small light, it needed an unobtrusive switch. I couldn’t find anything that would attach to the body, without looking out of place. I knew the S2+ pill was fairly deep, so I figured that I could mount the switch inside, & run an actuator to it.
With the pill assembled, it was installed firmly in the head. I would have to drill through the body & pill at the same time, to ensure the actuator holes lined up on final assembly.
With the hole drilled, I fashioned the actuator from a piece of silver-solder welding rod. A plastic sleeve was made to slip over the rod and switch pole, to keep the actuator rod aligned. An ‘O’ ring groove was cut into the rod, which keeps the rod from moving around, with the ‘O’ ring allowing just enough movement to actuate the switch.
With the switch completed, the pill had to be removed in order to attach the driver. Care had to be taken to avoid galling the internal threads, as the brass had some sharp edges from the drill hole that had to be removed prior to winding out.
Now to attach the driver, & re-install everything.
This was a real PITA; the ‘O’ ring had to be rolled onto the plastic sleeve first, & placed inside the pill. The pill then screws in until firm, where the body & pill holes line up.
The actuator is then pushed through & into the plastic sleeve, & then the ‘O’ ring rolled back onto the groove. …All with the driver & wiring in the way, deep in the top of the head…
As you can see, I didn’t go for all-out power with this one; just a modest 1.4a driver. 5 evenly spaced modes, beautiful moonlight, buttery-soft Nichia goodness from the frosted optic.
Here’s the finished product, with it’s family;
Thanks for reading! :beer:
Love it…thanks for sharing! I love those little S2+ lights.
Nice work! What is that thing you’re using as the spacer?
Nice build! Very good imagination to make the e-swicht
Very nice mod !
Wow !
Nice job , sir .
Very well done FMC! Thanks for the detailed how-to.
Cheers all :beer:
It’s a copper fuel injector seal from a diesel engine. Goes between the injector & the cylinder head.
It just happens to be an almost perfect size for the S2+ w/Carclo optic.
I don’t suppose there’s a cheap online source? Usually not with specific engine parts
this is very cool!
really clever! ;)
To connect switch atiny13, must be made flash mod?
or just connect to the PIN reset and GND?
These look like the ones, but I cant say for sure. Mine came out of a Toyota 1hd-fte.
They don’t appear to be cheap (at least on fleabay).
Yes, you will have to flash with a e-switch type firmware, such as STAR Momentary.
Depending on the firmware, it’s usually Pin2 (or the fourth star of a 105c).
Love it!
Very nice idea for the switch. Really cool build!
Nice switch! Love how it’s almost unnoticeable against the side of the light, but gives the full function of an e-switch.
I’m thinking of modding my S2+ mini 18350 into an e-switch light. My approach is much less professional looking though: Instead I’ll glue the e-switch onto the outside of the light then bulid a small casing around it out of aluminum, with a cut-down rubber boot.
Once that’s complete, the next step would be to cut down the tailcap. After all: one advantage of a sideswitch is that it’s no longer necessary to have space in the tail for a tail clicky. I figure this would will let me reduce my 84mm S2+ mini to maybe 74mm. The projecting sideswitch casing would also serve as an anti-roll mechanism. Battery would be the same IMR 18500 my S2+ mini is using now with an estimated OTF output of maybe 2500 lumens on a fresh cell.
Very nice work, I really like the Convoy S lights, so many great mods have been done with them.
Very creative. I like how descret it is yet easy to feal for and locate. I might have to give this a try.
wow nice build. big effort with the e switch
Sweet. Very nice mod. This is another thread that the pictures make everything look bigger than it really is.
If only it was bigger….
Did l mention it was a PITA…. :slight_smile:
WOW!! Awesome mod…never though I would see a side clicky on a Convoy S series tube light
