I do have a soft spot for those. I just noticed that the seller has changed the description to 3 mode but the last one I got was still 5 mode. I also use them as a cheap source of parts for home made lights.
Here's an interesting bit:
This light: http://www.ebay.com/itm/111460336700 - Currently $3.99
Purchased from eBay, and reviewed here: https://budgetlightforum.com/t/-/30302
...Legos perfectly with the Ultrafire 501b (at least the cheap host I bought from FT).
Nice if you want a different body for your light.
Thanks. I ordered two. I have two that look like that from some place like Banggood, and they have a brighter and warmer light than the more common similar ones with the scollop fluted head. I also think it looks much nicer. I am not sure about the pill.
Do you know what emitter it uses?
I bought a couple of these 2-A lights for $1.98 US and modded them with XP-G emitters. Great price for a solid 2-AA host.
That looks like a nice host.There was 3 available,logged in and all gone…bad luck this time.
edit: Few hours later I was able to order it,thanks for the link.
Shipping:
Does not ship to United States | See details
Item location:
HongKong, Hong Kong
Ships to:
Worldwide See exclusions
Jubeldum, see post 37
Thanks, I ordered one.
Anyone know if its glued or how the led sits, by pill or shelf.
The lens is glued or a very tight push fit. I had intended to mod mine but it turned out to be a surprisingly good little light stock. I actually got mine free as it was DOA and the seller gave me a full refund. Eventually traced the problem to a lack of contact between the body tube and driver (end of the tube was anodised). It’s now the best non-Cree light I have with a nice neutral tint rather than the usual blue. Throws well too.
I’m guessing it will have the standard plastic pill that goes with these straw hat LEDs but I haven’t opened it up to find out.
Ok thanks for the added info & picture, it really is a little mini C8 too bad you haven’t gotten it open yet, i hope i get it open in the end.
There not many good cheap moddable clicky aaa/10440 host around so i hope this one has some potential.
How big is the mcpcb in these? is it a good solid pill or shelf? i am thinking about putting a XHP50 or 70 in one of these little 2xAA hosts If i can find one that can take it that is :bigsmile:
Looks really interesting. Any additional info? Solid pill? What led does it come with? Was the head glued? It's cheap enough, so I ordered one. Thinking of reflowing a Nichia 119 onto it.
Might make a good glovebox light.
I’m also interested in all the details you can give.Reflector size etc.
To go with the mini C8 you could also get big brother for just $3.67.
It has the old XRE LED (NOT XML as listed) and probably a plastic reflector but is still a cheap host for endless modding possibilities.
Seller has a bucket load of negative feedback though.
I bought a couple of these 2-A lights for $1.98 US and modded them with XP-G emitters. Great price for a solid 2-AA host. http://www.ebay.ca/itm/XML-LED-1W-Torch-Lamp-Fishing-Camping-bright-white-light-Flashlight-New-DX-/271714376512?pt=LH_DefaultDomain_0&hash=item3f43705b40
Received the one I ordered. Initial impression is pretty good for the price. The light feels solid with threads that are fairly smooth. The anodizing/paint looks cheap and had a little bit of visible flaking right out of the package. The grey color is really shiny. I hope the shine isn't due to lead...
It comes with a cheap generic led that does about 20-30 lumens of cool white light. The tint is surprisingly decent, certainly more neutral than other cheap led's I've had. The mcpcb is actually held down by two screws! The driver is single mode and looks to use a really thin pcb. The switch is very stiff and uncomfortably hard to operate. Could have to do with the rubber boot.
Gotta source a cheap mcpcb for a Nichia 119...
Sounds good i hope i get mine soon, i want to use a XHP50 in one of them
Does it have a pill/shelf design? And if pill is it hollow? Is the switch modable?
