I guess each have their own preferences. When I’m hiking/camping I want a thrower with some spill (like the C8) and a floody headlamp.
True! To each his own. It was just a suggestion. Zoomies seem to pretty popular, so I expressed my thoughts ;)
1000 people 1000 ideas
I think there is starting to be a price jump when your start going over 2600mAh (at least for quality name brand).
Here are some low cost Ultrafires flashlights with the Cree XM-L T6 and you can get two flashlights for about $13.
http://www.ebay.com/itm/361146245924?\_trksid=p2060778.m1438.l2649&var=630491936237&ssPageName=STRK%3AMEBIDX%3AIT
Maybe 7 to 14 days shipping time, from China.
Set of 4 Trustfire 18650 3000mAh, $18.73
http://www.ebay.com/itm/141383193685?\_trksid=p2060778.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Takes 3-6 days shipping time, from California.
Set of 4 Samsung 18650 2600mAh, $18.65, use the “BLF” coupon code for a small discount.
Shipping from China, might take around 20 days shipping time.
I would take the Samsungs over the Trustfires.
Battery charger, something simple single battery and cheap, $3
slightly better dual battery changer, $7
Name brand (and better) dual battery charger $15
Really nice Quad battery charger, $30-$40.
Here is a Sky Ray King 3X Cree XM-L T6 flashlight, Winning bid is usually around $13 and shipping is $6.
http://www.ebay.com/itm/Gold-SKYRAY-30W-3x-CREE-XM-L-T6-LED-6000-Lumen-Flashlight-Torch-Lamp-Light-/121575294017?pt=LH_DefaultDomain_0&hash=item1c4e73c441
It will work with one or two or three or four 18650 batteries installed.
Guess you will want to order at least eight (or more) 18650 batteries for a camping trip.
The questions are:
- How long do you intend to keep the light? If forever, buy the best you can afford.
- Will this be used indoors, outdoors, close up? You have already said hiking.
I would go with one of three lights.
- Eagle Eye X6 with 3C tint - EE lights are among my favorites and there is plenty documented about this light. (Use code "BLF" for an additional 8%)
- Convoy C8 with XML T6-4C if you want to bump power in the future. This is a quality light and was one of the most popular before the X6 became popular (Use code "BLF" for an additional 8%)
- Convoy M2 with XML T6-4C if you want to bump power in the future. This is a quality light and is popular. (Use code "BLF" for an additional 8%)
The C8 is the most throwy. The X6 has a nice balance and comes with a clip also.
Samsung 18650-26F Very good price and very good battery. There are higher capacity batteries but if you look at tests you will see that Low Voltage protection kicks in before you get the full capacity out of the higher capacity batteries. (Use code "BLF" for an additional 8%)
Nitecore D4 Very good price for a very good charger
or ship the batteries separately…believe it or not $1 laptop pulls will work GREAT in that light with nary a problem
And +1 on the Convoy C8 as well
Thanks for the feedback!! I like the look of the C8. I think thats the one I am going to go with.
Also does anyone have experience with the light in the link below? Zooms and takes an 18650. I doubt the 2000L is realistic but seems like a decent piece for the price.
Yeah definitely not 2000 lumens. Probably 1000 if you’re lucky, 600-800 is more likely. I personally don’t like zoomies because the vast majority of the cheap ones are very low quality. I can’t comment on that specific one though.
I can’t comment on that light but would rather not get it.
Take a look at Convoy lights for best value to price ratio. If you want a zoom light try the Convoy BD04 It has an inbuild charger and looks sturdy. Don’t know if there are reviews jet. But the seller is great, you can choose what led and sometimes driver you want and they’ll assemble it for you. My suggestion is XML2 T6-4C.
Add a high quality 18650 cell and use your cellphone charger and you’re good to go.
+1
If you want a zoomie that’s a good one, and a great store to buy from.
edit: I agree with the below post. A C8 and a good, reliable headlamp that runs on alkalines.
Zoomie does not seem to be a good choice for your purpose because most of them are prone to water.
Besides a strong light like a C8, you also need a backup light that is small (to hold in your mouth) and with long burning time at a low setting for example thrunite T10 or Fenix E12. Or instead you should get a headlight to completely free your hands.
But the Convoy BD04 is a new one to me. It seems a quality light. Thanks for bringing it up.
Thanks. Is there a big difference between the XML2 T6 and the XML T6? I see on the one Convoy, you are able to select either of those. Not sure how much better the XML2 is than the XML.
You want the XML2 if its an option. IIRC it’s about 20% brighter. For outdoor use, you’ll want either a 3C or 4C tint probably.
Are you still looking at the C8 at fasttech? If so, I would go with this one
The orange peel reflector will give a smoother beam (but not quite as much throw)
I only suggested a zoomie you would at least get a decent one and don’t end up with nasty ultrahouseonfire lights. Convoy refelctor lights are great to: Convoy L4, C8, M2, M1, S3, S2+ are all great. So great that I have all of them. Choosing the led tint really sweetens the deal, no unknowns and you avoid blueish crappy light you get out of most cheapos.
The C8 is an awesome light, highly recommended. Another to consider, the ZY-T08 - $24.99 at Mtn but out of stock at the moment. $26.73 - 5% @ FT puts it close to your budget:
...That is if you want a thrower. 2x cells in parallel, so safe operation, with twice the runtime. You didn't specify if by bright, you wanted long range or wide flood.
I’ve bought 7 of those Ultrafire WF-878s, I’m sure realistically they are 600-800L, I guess $10 is a fair price.
You can order them off eBay (shipped from China) for about $8-$9, free shipping and no tax.
http://www.ebay.com/itm/Ultrafire-2200LM-CREE-XM-L-T6-LED-18650-26650-AAA-Flashlight-Focus-Torch-Light-/321400785323?pt=LH_DefaultDomain_0&hash=item4ad4fac9ab
I’m torn between flood and throw honestly. I favor a little more towards throw with still a decent flood. It looks like the C8 is able to satisfy that from what I can see.
I think you will be happy with a decent C8... Then the addiction will set in. First, a dedicated thrower. Then a dedicated flooder. Then....
