Zoomie does not seem to be a good choice for your purpose because most of them are prone to water.
Besides a strong light like a C8, you also need a backup light that is small (to hold in your mouth) and with long burning time at a low setting for example thrunite T10 or Fenix E12. Or instead you should get a headlight to completely free your hands.
But the Convoy BD04 is a new one to me. It seems a quality light. Thanks for bringing it up.
Thanks. Is there a big difference between the XML2 T6 and the XML T6? I see on the one Convoy, you are able to select either of those. Not sure how much better the XML2 is than the XML.
I only suggested a zoomie you would at least get a decent one and don’t end up with nasty ultrahouseonfire lights. Convoy refelctor lights are great to: Convoy L4, C8, M2, M1, S3, S2+ are all great. So great that I have all of them. Choosing the led tint really sweetens the deal, no unknowns and you avoid blueish crappy light you get out of most cheapos.
The C8 is an awesome light, highly recommended. Another to consider, the ZY-T08 - $24.99 at Mtn but out of stock at the moment. $26.73 - 5% @ FT puts it close to your budget:
...That is if you want a thrower. 2x cells in parallel, so safe operation, with twice the runtime. You didn't specify if by bright, you wanted long range or wide flood.
I’m torn between flood and throw honestly. I favor a little more towards throw with still a decent flood. It looks like the C8 is able to satisfy that from what I can see.
Thanks for all the feedback! You all have been very helpful. Still a little confused with all the possibilities but you have all helped me narrow down my search.
So I am looking at the one in the link below. the one that is XML2 T6-4C that does not have SMO next to it. I would figure that would be the OP but it does not state that. Thoughts?
