Dale ordered 50 - Will you send to the Europeans?
I’m not sure if this makes sense with letter costs from the US and shipping times?
I’d be willing to go ahead at 34, will fill the order to free shipping with some other parts. But I’d like to wait on Dale’s reply since he allready ordered.
So yeah, y’all better make sure they’re all accounted for!
There was a pretty quick interest in 30 of em. If I’m keeping 10 then it’s easy to see why I got 50 for the price break. This allowed me to get em for $1.71 ea. That will help a little to offset some costs to the European modders.
I too was wondering how 4 of these would do in a quad, de-domed….
Correct me if I’m wrong. I just looked at the Cree Product Characterization tool a little while ago. It has specs for the various emitters and there are three columns so that you can compare multiple emitters to each other directly. I chose: XP-G2, XP-E2, and XP-E2 Torch to compare. I see that the XP-E2 Torch is rated for higher amperage than XP-E2. But, other than that, the performance is not as good as the XP-E2, and not even close to XP-G2 when you measure in lumens-per-watt. The XP-E2 Torch also has a significantly higher Vf than either of the others. Really, what is the draw here? :~
Edit: I should say, total lumens output is higher than XP-E2 because of the higher Vf and being rated for higher amperage. But, really, is the XP-E2 that much smaller than XP-G2? Because, the lumens-per-square-mm would be the only advantage I can think of that this thing might have.
