Sounds like you have both a real RAT 1 and the aliexpress clone? The Real RAT 1 has Nylon handles but the aliexpress clones show G10 in the description. Can you compare with the real one and report the difference and if the aliexpress clone actually has G10 handle material?
I can get a real RAT 1 locally for $25, same price as most clones on aliexpress (although there are a few for $19.99) I’d like one in G10 instead of nylon.
Either way I going to get one of the clones too because I’d also like a Fluorescent green one and I don’t think Ontario makes it.
For the black G10 I may just save up for the RAT 1A (Assisted opening & G10 scales)
Here’s a photo I found comparing the real RAT-1 to a China knock off:
(China clone is the larger green one on top - real RAT-1 is the tan one below it, other 3 are ESEE Avispa & Zancudo)
(both photos found on bladeforums)
Notice the RAT-1 clone is marked RAT model 3, which is actually a fixed blade knife.
I really like the drop point blade shape on the ESEE and it’s framelock may be stronger than the linerlock on the RAT, but for that you give up having handle scales on both sides, for me it’s a tough decision between the ESEE and the RAT.
That looks really nice! But the handle seems small. I like ebony and am ordering that same one. It says “440C 58HRC” in the description and 440 on the knife. It doesn’t say where it is made in the description, but I it says China on the knife.
GPKnives doesn’t seem to have anything budget.
The lanyard hole is further back lined with a tube I think. The larger hole looks like the wtf hole on the Sebenza (wtf in this case stands for what’s that for. :bigsmile: )
I’ve certainly not seen a SOG of that design before.
I have an Elk Ridge branded knife, although some might think them not up to par I’ve had zero problems with mine the few times I’ve had need of it it performed well.
8¾” blade full tang. Elk Ridge definitely China Made.
I guess the definition of “budget” varies widely. GP Knives has a lot of very nice blades from quite a few custom makers. When you can get a well made knife with a top blade steel for under $200, in many cases $120-140, to me that’s budget. Sure, there are also $6500 knives there, which makes the sub $200 knives look like quick grabs.
The exotic woods, giraffe bone, warthog tusk, water buffalo hide sheaths… some gorgeous work on those blades and a great many are priced very attractively.
Wouldn’t you know the one single blade on the entire site that I feel I MUST have is out of stock?
Hey guys, I’m really digging the looks of the Boker Kwaiken, especially the flipper version. I like the shape of it. Is there something similar to this in the budget realm?
Somewhat similar shape but may not be considered budget at $35 is the CRKT Heiho:
I own one of these and it’s a beautiful knife and excellent quality, extremely sharp out of the box. Slight tanto shape blade and no flipper but it has the OUTBURST Assisted Opening system. (I paid nearly $50 for mine with no regrets so $35 is a great deal)
It’s the little brother of the all black CRKT Hissatsu Folder (which is about the same size as the Kwaiken)
An even larger similar shape knife is the CRKT Otanashi noh Ken But that ones only about $10 less than the Kwaiken.
Timber Rattler Scarab, with a Cold Steel Kobun beside it for comparison.
While it isn’t particularly well made, a bit of blade movement side to side, and the steel isn’t anything to write home about, it is enormous. For $25US it’s probably the king of budget knives (well based on size anyway).
Heard of one guy who got into trouble because he had a Swiss Army knife in his pocket. When he was brought before the judge the judge turned around and said, “I carry a small knife, I know a lot of people who do, case dismissed.”
I wouldn’t recommend that with the Scarab though. It’s not a particularly good knife, but it would be a great thing to hang on the wall or keep on the coffee table. It reminds me of the folder Mick Dundee had in Crocodile Dundee 3 (although the rest of that movie was forgettable).
It’s somewhat close, but not quite Kwaiken style. I think the Kwaiken kind of reminds me of a Higonokami style knife. The straight lines from the handle to the blade is what attracts me to Kwaiken. There seems to be a lot customized Kwaikens out there. I would have thought that there would be more interests from Chinese makes to make something similar. I guess maybe it’s not quite as popular or it’s already fairly inexpensive($100?) knife.
The closest thing I have to it is a Sanrenmu 704 which kind of of looks similar; blade is not quite the right shape (more spear shaped). The 704 is also smaller overall.
