About Singfire SF-715
Would you be so kind to specify the head and reflector diameter , also driver diameter: any active codes for it?
It seems it could be a usefull hunting light
Can it be ordered without a battery and a charger?
Anybody know if the Nitecore D2 that Gearbest is offering for $18.89 is the same thing as the “Nitecore D2 Digicharger 2015 New Version” that Amazon is seliing for $19?
(More generally, what’s with the year dates on Nitecore chargers? I’ve seen “New 2014” for a while and now this “2015 New Version” —- what’s the diff?
Does anyone miss the GearBest deals, today I bring all of you the amazing budget flashlights deals ( all under $5 ) and other crazy deals without using the coupon.
(When the LED lifts up, either there’s a flat aluminum surface behind it (with 2 holes for the wires) — that’s a “solid pill”
OR, there’s a hole and you can see inside the pill down to the electronics on the driver (that’s a “hollow pill”)
If you can lay your hands on one and let us know, it’ll be worth knowing.
I’ve been looking for those with the solid pill — they’re hard to find and very easy to mod with better/colored emitters
