alexvh's firmware. Update: Hidden strobe, Ramping and optional mode memory added.
111 posts / 0 new
pyro1son
pyro1son's picture
Last seen: 2 weeks 5 days ago
Any chance we can get a version of this with a hidden beacon instead of the hidden strobe?
Pastebin                                      &nbs
alexvh
Last seen: 3 years 4 months ago
Is there a standard beacon? I’ve never used a light with one. How long on, off, how many flashes etc?
My firmware for nanjg attiny13 flashlight drivers: https://github.com/alexvanh/basic_off_time_driver
Discussion: http://budgetlightforum.com/node/36932
Off-time mode switching on stock drivers (no off time capacitor mod necessary) and ramping withou
ToyKeeper
ToyKeeper's picture
Last seen: 6 hours 19 min ago
I’m not aware of any sort of standard beacon, but there are a few I find useful… one is what I call a heartbeat beacon, which flashes in the following pattern:
  • On 5ms
  • Off 245ms
  • On 5ms
  • Off 745ms
  • repeat
Another I find useful is a looping battery check mode, which flashes once for each 25% of the battery’s current charge, then pauses and re-checks and repeats. It’s more like 100ms on-time with 400ms between, and 2-3s between cycles. If left on for a long time, the number of flashes will decrease until the light eventually shuts off.
One more thing to consider is the brightness. A signal beacon should be pretty bright, but a “find the light indoors at night” type beacon should be dim. For the latter, one popular approach is a short (~3ms) flash at a moon or low level every 2s.
The one I use the most is a stutter beacon, used on a head light or tail light while biking or skating. It stays on all the time, but changes brightness to make itself more noticeable. The pattern I use there is:
  • High 5ms
  • Low 65ms
  • High 5ms
  • Low 65ms
  • High 5ms
  • Low 65ms
  • High 5ms
  • Low 65ms
  • Low 720ms
  • repeat
So, 4 brief high-brightness blinks and then it rests at low, and repeats at 1Hz. As for the levels to use, I’ve found that 40lm / 400lm works well, or 7lm / 150lm. There must be a pretty big difference between high and low.
pyro1son
pyro1son's picture
This is what i was thinking.
Although would have to check the timings to see if they are suitable.
Pastebin                                      &nbs
alexvh
Do you want a hidden beacon instead of the strobe? Or a bunch of “strobe modes” including beacon modes, accessible after activating the strobe?
pyro1son
pyro1son's picture
I was after a hidden beacon and no other flashier.
Pastebin                                      &nbs
odd
Last seen: 2 years 4 months ago
quick and dirty:
static void inline pwm_strobe()
while (1){
PWM_LVL = 255;
_delay_ms(20);
PWM_LVL = 0;
_delay_ms(90); // change the parameter 90 to up to 65535(ms you want the light to be off)
pyro1son
pyro1son's picture
Ahhhh that’s great I’ll try that out after work! Thanks!
Pastebin                                      &nbs
alexvh
odd wrote:
quick and dirty:
while (1){
PWM_LVL = 255;
_delay_ms(20);
PWM_LVL = 0;
You would have to move the pwm configuration code up a bit as well, since you are using pwm here. You could just call strobe2(on, off) instead, with the values you want.
JonnyC
JonnyC's picture
Last seen: 2 months 1 day ago
Late to the party, but great find alexvh and DrJones!  This would actually work the majority of the time for me as I usually set the OTC to around 500ms.  I still have a roll of probably 100 capacitors, so I'll just stick with the "traditional" method, but this is a sweet solution.
Mike C
Mike C's picture
Last seen: 3 weeks 1 day ago
Thought I’d update this thread with some info… This brownout method for short presses works a little differently with some of the low voltage MCUs and the “standard” 10uF input capacitor. It takes a lot longer for the memory to decay. Seeing this on the 84V and 85V.
It can be useful for retaining data during long presses with off time cap, but a little annoying when function testing firmware.
ERDOS
tested on ak47a and now this is my favorite firmware. Love the hidden strobe. Can you add a battery voltage indicator ? and maybe a step down when voltage low :bigsmile:
mk2
Last seen: 4 years 11 months ago
I registered here to thank you for this awesome firmware.
Again confirmed working on AK47A .
A minor code correction, strobe2(uint8_t on, uint8_t off) should use uint16_t or else the compiler gives a warning.
I like this beacon timing: strobe2(10, 1000)
Big Smile
ToyKeeper
ToyKeeper's picture
The 16-bit int is only necessary if you want to “strobe” slower than 4 Hz (meaning one of the parameters is larger than 255).
mk2
I added these features, available here http://www.mediafire.com/download/up56daf8jg6l6u4/mk2_FW_mod-20150608.zip
Includes:
  • low-voltage monitor; 4 sec low light warning and shutdown at 2.9V
  • battery check mode
  • 7 modes + hidden strobe: moon, low, med, max, batt, beacon (10/1000ms), ramp
mk2
I made a few FW versions for different applications:
1A driver for bike light
6 modes + hidden strobe: 2Hz-flasher, moon, low, med, max, batt
moon 7mA
low 50mA
med 240mA
max 1A
1A driver for EDC light
7 modes + 3 hidden strobes: moon, low, med, max, batt, 1s-beacon, ramp
moon 7mA
low 50mA
med 240mA
max 1A
3A driver for EDC light
8 modes + 3 hidden strobes: moon, low, med, high, max, batt, 1s-beacon, ramp
moon 5mA
low 40mA
med 200mA
high 600mA
max 3A
All FW versions feature:
  • off-time functions without hardware modification
  • memory is disabled because it is less relevant in off-time operation
Available here http://www.mediafire.com/download/huqfta48×9hkmdd/mk2_FW_mod-20150610.zip
Thanks again to Alex and others for their source code.
ps
If you can’t flash high-amp drivers check http://budgetlightforum.com/node/29684?page=3#comment-771123
mk2
I coded a hardware interrupt-driven “survival” beacon with 5ms of full power and 2000ms off-phase with current drain of less than 200uA which allows the beacon to run approximately 3 weeks on a fully charged 18650. It is possible to reduce off-phase current drain to less than 10uA if the R1/R2 resistors are increased. Has anyone tried higher values eg. 220k/47k? What’s the input resistance of PB2 itself?
alexvh
From Table 18-8 on page 121 of the datasheet, analog input resistance is 100M. Giving less than 0.01uA, nothing to worry about.
mk2
Thank you, then I will use 220k and 1M and update ADC levels for the “battcheck” function.
aw73
Last seen: 4 years 4 months ago
What would be a simple way to add a turbo timer or high mode step down?
