Yep. Gotta thank vex_zg for it. He showed me his setup and had relays to spare. It saves a lot of time.
I was starting to get aching hands after all unclipping… well, almost.
The photo is slightly old, I’ve added a little to the setup. I’ve attached a SIOC14 clip to the remaining pins the relays so I can just as easily program the ATtiny24/44/84. Button pushed is the SIOC8 clip, button released is the SIOC14 clip. The other button is just a convenient power button not attached to the relays.
One thing nice about connecting the programmer with that color, 40-wire ribbon is that you have lots of extra wire to fool around with stuff like this.
For now, I added something like that to the INDEX file. It lists each project with a one-line description, pulled from the ‘meta’ files in each project directory. The meta files aren’t all complete though, or reviewed by the owners of the projects they describe.
hex files for me is difficult - there's so much tweaking that needs to be done now, depending on the driver board. Plus I got a zillion mode combos goin on... Wish I had a super batch build job that I could run to generate all possible combos, but might result in dozens . Basically I have to mod the source code for every build - very little direct re-use.
Well my youngest Son is going to Michigan Tech next year for computer engineering maybe I can talk him into helping out. LOL
I actually went to college for computers in 1987 and was learning a little bit of this kind of thing before I dropped out. I was pretty good at math but doing math in hex was something else! Probably don’t have to do that anymore?
Too much partying, chasing girls and that kind of stuff and that was it for me. Went back after leaving the military but not for computers. Still I’ll have to give compiling hex files a shot here in a while. For now I’m just happy to be building some of my own drivers. I should have started last year this time maybe by now I would have something to offer instead of mooching from you guys.
I generally mod the source for each build, tweaking modes and levels and values and so on. I copy the original source file to one named after my light or named after the person I’m building it for, tweak it, build it, and keep the files around for later reference… but I don’t add them to the code repository unless there are significant functional changes.
It’s nice that STAR and guppydrv allow the end user to change the configuration, but the attiny13a is so limited that even those firmwares need to have a few different builds to support different types of lights and drivers. And the majority of the limited space goes to runtime configuration options.
But code which isn’t designed for runtime configurability… will generally need to be recompiled for each light and each person instead of using a pre-built hex file. And if it’s only modified within its intended range, like tweaking the #defines, I don’t find it worthwhile to commit that change to the repository.
Basically, take the default #defines as an example, a suggestion. But you’re usually supposed to change those and rebuild for your personal needs.
- I started out as an EE major in '75 after high school. took my first computer course of Fortran on cards (don't drop the deck!), and later dropped out, then went back to a tech school for programming, then continued CS courses at night. Never got a BS degree but took all the CS courses... in about '81, bought the IBM PC - 1st version, DOS 1.0, etc. for like $3,500, stripped down. Added my own memory chips to get it up to 64KB - the fun began...
That is very cool. Our high school had apple computers in the mid 80’s and I could do the “if and then” statements with the best of them and ended up being the teachers assistant my senior year.
The first time I saw a computer was at my Mother’s job. She worked for a place in Saginaw Mi. that did the payroll for the City and a bunch of other large businesses. I remember going there to see the huge rolls of tape and all of that. I’m sure that was Fortran and probably some of the very earliest commercial use of computers. Time-cards turned into paychecks, I think the place was called Fullerton if I remember correctly.
Funny for me really, considering we are family of farmers. But farming is more and more high tech now. I sold feed for a while and we used a program out of Michigan State for figuring out the optimal feed requirements for dairy cows. We tested all of the feed grown on the farm and then balanced that with the stuff we sold. My Father sold fertilizer and they did the same thing for that. My Grandfather could do the math in his head faster though. LOL
In '78-early 80's, the job market was insane. I had multiple job offers coming out of the tech school - 6 month certificate in computer programming - oh boy... You switched jobs every 6-12 months to get a 10%-20% or greater bump each time. I got 20%+ counter offers just to stay at a couple of jobs.
All that doesn't make me an expert at Atmel/AVR programming though, so the learning never stops... It still blows me away that they can fit so many components/features into 1 tiny chip.
Here is one way to achieve customization of firmware without recompiling and only editing one hex file. The EEPROM can be loaded from a hex file. Configuration data can be put into the EEPROM hex file, edited, and programmed to the MCU. Since the EEPROM hex file is separate from the program hex file, it can be programmed by itself.
This would beneficial to those who have the equipment to program the MCU but not the software programming skills.
You don’t need software programming skills to change mode levels. All you need to do is change a few numbers. Star is basically written for easily defining modes, mode direction, memory, timeouts etc etc… It’s pretty easy to grasp.
Is there any idea of what the "OFF" current of momentary firmware can be? Any ideas whether the current is in the few microamp range? Or are we talking tens or hundreds. Do any of the mom. firmwares go to sleep mode when "OFF"? Would using the reset pin PB5 for the switch input allow for deep sleep? (It would probably remove the possibility of short/long press detection.)
I'd like to run from a single AAA cell where capacity is quite limited.
From what I recall, I measured the “off” current on Ferrero_Rocher to be about 0.36mA with the green indicator LED on (dimmed), or about 0.33mA with the indicator off. About 1.23mA with the indicator on full. So, anywhere from ~10 to ~45 days of standby time on a 10440 cell.
But that’s without seriously optimizing for standby power; IIRC it can get significantly lower with the right code. Atmel published the specs but I don’t recall the actual numbers.
What I want to know is how you fit an e-switch into a 1xAAA light.
Oops LOL I didn't mean an e-switch AAA, like an EDC, that would be tricky (but possible). I was thinking of retrofitting a headlight driver as it already has the e-switch. What I'd like to design for is say 80% remaining capacity after 30days of standby. (or 90 days better yet) If you use all the capacity in standby time then its no good.
The tiny13a draws 2uA in power-down, but requires a reset or power cycle to recover (correct me if I'm wrong). That's why I wondered about using the reset pin for the e-switch input. I'd also need some way of disconnecting the ADC resistors to eliminate their current.
A standard nanjg has no offtime capacitor (OTC) so starry-offtime wouldn’t work on it. However, basic STAR and STAR_noinit should work, and so should anything listed under “mem decay” or “ontime” in the INDEX file (as long as it’s also listed under attiny13a).
You should also make sure that the switch type matches — clicky or momentary. I’m guessing you have a clicky.
Sorry, I meant Nanjg 105c with an otc installed. I was just hoping to use some of the advanced features of starry-offtime but was unsure about the secondary channel bits. I'm currently running STAR offtime on the driver in question.
