I don’t use either of these firmwares so I haven’t tested, just took a quick look at them. The A6 firmware assumes R1 us 19.1K. The battcheck has no notes on what R1 should be, but I assume that it’s also based on R1 being 19.1K as it, together with the 4K7 R2, appears to be the standard. I use these resistors in all my single cell drivers because they work, no need for me to change.
I just did a check and the voltage difference is however not so big between 22K and 19.1K (just under 0.1V), so I guess this is not the problem. Have you checked with a DMM that the PB2 pin on the MCU is receiving correct voltage after the divider? EDIT: If you read 3.2V on the MCU’s PB2 pin with those resistors you have probably swapped R1 and R2.
Something isn't right here, those values should work just fine. There must be another problem you have yet to discover, are R1 and R2 swapped? (R1 goes to batt+, R2 goes to GND) Is R2 open? Measure the voltage at pin7 (ADC input), it should be in the 0.5V to 0.75V range, if not, find out why. If the resistors were removed from another board, they may have been damaged. If they are new, double check their value to be sure they are correct.
The resistors are in the right place and they are new, resistance value is correct. The voltage at pin7 is 0.56v.
Maybe i have a bad MCU? I flashed it with the blf-a6 firmware and modes are working fine.
Did you load BattCheck.hex or did you compile your own version?
I can't believe there is a problem with the MCU, but I've never heard of this problem you're having. I guess its possible an ESD hit took out the ADC and left all else intact...
I got nothin'
If you do replace the MCU, and that works, I'd be pleased but puzzled.
It appears to be limited only by available RAM and ROM. With alt PWM enabled, you’re probably limited to about 15 modes, and without that you might be able to get 20 or 25 modes.
If you want enough modes to make a smooth ramp though, you might want to look into Ferrero_Rocher/Ramping_UI_table.c instead.
Just FYI - It hasn't been announced "officially", but the TheStar FW has been available in TK's repository for some days already (both on- and off-time versions are there).
Feel free to try it and report your findings to me. Thanks in advance.
If this is too much OT for this thread, the discussion can continue in the old TheStar thread.
I should better to edit VCC to B+. Don’t be confused with the VCC of the MCU. The VCC of the MCU ( Pin 8 ) must not higher than 5.5V.
The voltage divider R1 and R2 are employed to lower the B+ voltage into the ADC reading range of 1.1V reference. I was confused what 200 resistor and which driver you are talking about.
Would you please post the schematic of your driver.
Oh, I see. The solder pads of the diode was replaced by a 20K ( 2002 ) resistor. Then the resistance of the voltage divider R1 is 20K + 19.1K ( 1912 ) = 39.1K and the R2 is 4.7K ( 4701 ). When the battery is 6.1V, the ADC value is 152.
Would someone be kind enough to tell me what is being written to EECR when it says 32+4+2.
Is it binary or hex or something
I’m used to doing EECR |= (1<<EEMPE); etc
Just can’t figure out how the numbers relate to the register
. EDIT: ok, got it, ignore me. It’s binary
You need to be careful here, because you aren't monitoring each cell individually. You need to account for the very real possibility of one cell dying before the other. If you assume that the typical cell voltage to be 3.7V and the lowest you want a cell to go is 2.8V then perhaps 6.5V might be the cutoff for two cells and 10.2V for three. Of course you can always plug in different numbers and recalculate. I can't say those are good values or not, and certainly not in all situations. I just think it is best to error on the high side; leave a little juice in the cells rather than risk damaging them, or worse, damaging yourself (or the trusting soul that is holding the light for you).
As was stated, always use identical cells in series and/or parallel arrangements.
