Samsung INR18650-25R 2500mAh (Green)
Official specifications:
- Nominal discharge capacity: 2,500mAh
- Nominal voltage: 3.6V
- Standard charge: CCCV, 1.25A, 4.20 ± 0.05 V, 100mA cut-off
- Rapid charge: CCCV, 4A, 4.20 ± 0.05 V, 100mA cut-off
- Charging time: Standard charge : 180min / 100mA cut-off
- Rapid charge: 60min (at 25°C) / 100mA cut-off
- Max. continuous discharge: 20A(at 25°C), 60% at 250 cycle
- Discharge cut-off voltage: 2.5V
- Cell weight: 45.0g max
- Cell dimension: Height : 64.85 ± 0.15mm, Diameter : 18.33 ± 0.07mm
- Operating temperature (surface temperature): Charge : 0 to 50°C (recommended recharge release < 45°C), Discharge: -20 to 75°C (recommended
- re-discharge release < 60°C)
- Storage temperature (Recovery 90% after storage): 1.5 year -30~25°C, 3 months -30~45°C, 1 month -30~60°C
This is the high capacity, high current cell from Samsung.
There is good trakcing between the two cells and the capacity does only drop slowly with load. The 30A discharge is to high for this battery.
Conclusion
This is one of the good high current, high capacity batteries, it has good performance, but it is not the best of them.
Notes and links
Compare to 18650 and other batteries
