FS: XML2 XPG2 XPL XPL HI MTG2 XHP50/70 Components + Extras inc. mod service RE-DESIGNED
Sliced DOME is the way to go…….
My MTG2’s DeDome look considerably less bright vs. Dome-On equivalents (all variables equal).
Sliced, you don’t notice the Lumen Loss and the hotspot IMHO is much improved. This may be the very best innovation since SLICED BREAD :bigsmile:
How close to the led wires do you make the cut 1mm / 0.5mm, less? Are you using something to guide the razor to the selected height?
I think the full de dome will always leave a tighter hotspot, but sliced has its uses, especially the tint staying the same/similar
There will be lumen loss in full de dome but gains in a tighter hotspot, personal preference I suppose!
All my bigger reflector end lights are full de domes
It depends on the emitter, mostly a washer or centering gasket to guide it with a single slice to stop jagged edges I’d say between 0.5mm off the bond wires hard to tell exactly because the remaining dome magnifies the wires making them look closer.
Do you offer sliced triple XP-Ls too? If so, will they fit under carclo optics?
Yes… And yes
I’ve just put 1 sliced XPL on a triple with carclo optic and it fits ok, the bottom of the optic touches the left over ‘dome’ so if it was screwed down tight it might do some damage? Maybe not?
This is just the first test but yes, it fits nicely
Good to know, thanks. I might be getting some from you.
No worries, whenever your ready!
I will now be offering a Finest de domed tint service for an extra fee, I will hand pick the best de domed tints.
I prefer neutral towards the more cool white tints so my ‘FDT’ will be as based off my eyes.
This means the FDT will be a cooler white with least green.
The idea will be to steer away from the greenish tints that can be possible with de domed emitters.
This also means the emitters will be CW before de dome ie. U3 1A,V5 2A, R5 1A
The emitters will be tested at 3A. (Lower currents tints can look different)
The extra fees will be:
FDT XPG2 - £6
FDT XML2 - £7
FDT XPL - £7
The extra prices might be steep for some, it is due to the volume of emitters sold and the fact that it is not in a light, this means the profit that would be made on the light can not subsidise the FDT emitter, it would end up costing me money (hope that makes sense)
I have to de dome a lot of emitters to do this which also costs me money.
However there will be a discount if you buy a modded light from me with FDT
Free GITD gasket with each emitter purchased (XPG/XML/XPL) info here: FS: GITD insulation gaskets XML XPG XPE XPL XHP50 nichia
Hello,
I want to to ask if i have chosen the right LED for my new Host.
The Host is a Convoy M1 (https://www.fasttech.com/products/1277400) and i want to use a De-domed XML2 U3 1A 6500-7000K 20×1.55mm DTP Copper.
If this is the rigt LED please can you give me a price for the LED inkl. shipping to Germany?
And maybe someone know if i can use this Driver for the build (https://www.fasttech.com/p/1186301). It would be nice if i can use the Driver because i have already two modded onec here. I added two extra AMC7135 350mA on each board. So that i get 3,5A out of it. I hope that the Convoy M1 can handle the heat better than the WF-502B Host because the 502B is getting very warm after 2-3min.
PM sent
Edit: and yes you can use the driver you mentioned
XPL HI V2 1A and XML2 U4 1A available soon! (En route from Australia)
XPL HI V2 1A + XML2 U4 1A have arrived! (Well after I payed a £20+ customs charge) :frowning:
how much for 3pcs XPL HI V2 1A sent to Austria?
PM sent
I will reserve items for 24 hours only after the 24 hours they will go back on sale or to the next person in line who wants them
totally agree with that!
I’ve got about 3 pending orders all wanting Multiple XPL HI! Haha, seems the fairest way to put 24 hours reserve on, otherwise all my stock would be permanently reserved :stuck_out_tongue:
I have re-designed the thread, hopefully makes it easier to read :slight_smile:
