The Windyfire fit fine, but not any of my NiMH batterys fit not even close.
I actually tested 2 Windyfire in it………it got VERY bright for 15 second but then it went dim i was going to mod it anyway
For an maybe 1W LED or less i was surprised it did light up at all & it actually looked great before it burnt out. I remember i had time to think if it keeps working i may leave one stock before it went poof.
To bad i haven’t received the XHP50 to fix it up yet.
Duracell NIMH (Japanese Eneloops ?)did fit my torch,it was tight.I replaced the led with XML2 and new reflector.I also soldered new boost driver to the aluminum pill.The light output is nice,but this torch is quite heavy with some heatsinking,so it feels like a good host for more output.
5-Mode 800mA From FT (SKU: 1127407).The reflector is a leftover from Convoy s2+ project.It’s only 21mm wide (12mm dep) ,fits Ok against the lens.Very nice flood but the reflector opening still blocks some light and the beam is almost square.
I am in need of something cheap to sit and stare at for a few minutes test out and maybe giveaway to friend or two. How bout something $10 and under? Something that hasn’t already been listed.
Side clicky, Single AA, three-mode High/Low/Strobe driver with memory, available in 9 colors.
Has a proper hollow aluminum thread-in pill that takes a 16mm PCB and a smaller (15mm? I didn't have my caliper handy to measure) driver.
Plastic reflector/lens is largish for the light size, so possibly some throw potential. Lens and SMO reflector are pressed in via the front, so not much room for modification there. My sample had some scratches on the ring, and a smudge on the reflector. The opening on the reflector sits perfectly on the ring of an XR-E emitter, so possibly a good mod host for your old XR-Es left over from other lights.
Factory emitter is one of the cheap "plastic dome over a yellow glob" type emitter. Mounted on a 16mm PCB, so it's easy enough to remove/replace.
I was going to say that I found the XP-1 even cheaper at $3.78 but on closer inspection it doesn’t look quite right.
The switch cap is shiny and the clip is different.
I just received another one of those S5 copies, this time it’s labelled Vander on one side and OUTDOOR (quite nice actually) on the other. Quite a relief from Ultrafire and CREE.
Also, Vanderbilt graduates can rejoice that their university is popular enough
The reason I am linking this is that it is a good host.
1. See the tailcap and its glorious screw-in tail. So much better than pressfit version that’s plaguing 90% of cheap lights.
2. The pill is… SOLID… for those solid-pill enthusiasts in here.
3. The pill is also connected to body through screw-in washer, put this on tight enough and you’ll still have good direct thermal conductivity to body.
4. It’s 3 bucks. Nice host and fresh branding for this price.
The driver and emitter is lame though. Bluish bottom end tint emitter, and cheap 3-mode driver. This is good for harvesting host only, and you have been warned. :bigsmile:
