My Bike Lights - Info, Teardown pics, Beamshots, Current Measurements, etc. . .
UPDATE: New Flickr Album Link: https://www.flickr.com/photos/garrybunk/albums/72157662737583937
Just received my GearBest 3x XM-L2 bike light for review light yesterday. I hurried up and grabbed some beamshots last night while the weather is still decent and there's no snow on the ground. This thing is a seriously bright flooder! Check these out:
What really impresses me is that this light only pulls 0.92A from an 8.26v battery pack on high. It also runs on a 4.2v pack (same two cells in my 2P1S battery carrier) and pulls 2.02A from that. So that's roughly 0.67A per LED. That calculates out to roughly 5.5+ hours of runtime on high on an 8.4v 5,200mAh 2S2P pack (your average 2600mAh cells)! After reviewing in stock form I'd like to see if I can mod the driver for higher output. I haven't torn it apart to look at heatsinking or the driver yet. Stay tuned for a full review.
-Garry
Update on the KD Duo/Yinding Clone. Good news! KD responded to my inquiry about buying the driver used in sku#S023788 (the "10-step user programmable" one reviewed by ledoman). They will sell the driver for that light for $8. They also reminded me that for my 4.2v version light the LEDs would need rewired to series (I appreciated hearing this from them as it showed me they had some knowledge on what they were telling me about driver replacement). If interested, you would just have to contact them and say you wish to purchase the driver used in bike light sku#S023788.
-Garry
UPDATE: New Flickr Album Here: https://www.flickr.com/photos/garrybunk/albums/72157691589882004
So I received my NiteFighter BT40s yesterday (unexpected fast shipping) and I'm quite impressed. It's definitely a step up from the $15 (+ shipping) Ebay MJ-872 clone. Bought it on sale for $23.XX.
First off, the lights are identical in size; I thought the NiteFighter would be a tad longer, but it's not. They are pretty much identical in construction, except that the silicon button (one "button" works the up & down switches) is much better on the NiteFighter. Like Andy has mentioned previously, the nubs on the inside of the silicone button are in the opposite direction of the switches, but it works fine. The rear of the light unscrews and reveals the driver (which I have not pulled out all the way yet). There is a nice o-ring at these threads. The front bezel unscrews easily (tip - use snap ring pliers to remove these easily), however there is no o-ring here. The bezel does screw tightly up against the optic though which will keep it mostly water resistant.
The optic was a little tough to pry out, but after working around and around I finally got it to pop up. It's not secured by anything other than the pedestals resting in holes, the openings pressed over the LED domes, and the bezel screwed against it. The emitters are mounted on a single pcb which is mounted against a solid backing which is part of the light body!!! Woohoo! (Note - I checked the $15 clone and it is identical too.) There was even a good amount of thermal compound in place evenly spread out! (Note - the $15 clone had way too much of a very runny compound in place.)
My light tested at the following current draws on 2 fully charged unprotected cells in a Pannova case:
Low-0.43A (20%)
Med-0.95A (44%)
High-1.43A (67%)
Turbo-2.14A (100%)
EDIT - I believe the original "2.14A' measurement was a fluke (perhaps higher current draw due to lower input voltage?) Turbo should be 1.75A for 0.875A per emitter before losses.
These currents are higher than I tested on the $15 clone (which reached 1.48A on high. The 2.14A on high roughly translates to 1.07A per LED. An XP-G2 on aluminum star @ 1.0A puts outs roughly 350 lumens (not accounting for losses), so we're talking roughly 1,400 lumens. I do believe this light could be pumped up quite a bit more. (Note: I was experiencing quite a bit of voltage sag even when I tried 4 cells, and I wonder if that is due to the battery pack / lights cabling. It's possible that the light would pull more current with better cabling, high-drain cells, or from a power supply.)
There is driver hum in all modes except high. (The $15 clone also has hum but I could only hear it when held up to my ear.) I don't believe this hum would bother me in actual use. I'm not susceptible to PWM, so I can't comment on noticing any. There is a slight fast fade up and down from one mode to the next.
I compared the tint to a XM-L2 T6 3C and an XM-L T6 4C and I'd say the NiteFighter is between the two, but very close to the 4C, a nice creamy white, definitely not orangish.
My PhotoBucket gallery is here, but here are a few pics posted:
Driver (same Andy?):
Bezel removed revealing star mounted with thermal compound:
Solid backing! Direct thermal transfer to the body!
For comparison, my older $15 clone:
Two side by side (NiteFighter on the right):
Again, NiteFighter on the right;
NiteFighter on the LEFT this time:
Sorry, no beamshots yet. On my basement wall it defintely looks like a wide swath of light as expected (same as my $15 clone, but a bit brighter).
UPDATE 10/2015
new close-up driver pics:
other side:
-Garry
This has been bothering me for a long time.
I have trouble seeing Garry's photos.
Here is an example of what I usually see:
If I quote Garry and maybe refresh my web browser (Google Chrome), I can usually see the images.
I've noticed that deleting "~original" at the end of the "direct link" that Photobucket gives you might solve the problem for posts 13 and later in this thread.
Is anyone else having trouble seeing Garry's photos (in posts 13 and later)?
I used to use Opera (which runs on Chrome engine) and got so fed up with this very problem that I switched to Firefox. I just did a test with my old Opera installation and could see the same problem. It took a while to get all my bookmarks and add-ons running on Firefox, but today Iā€™m a happier man. Good riddance piece of sh*t browser!
This is a great thread Garry. I have to say though that after using CW on bikes so the past 2-3 years and finally getting a NW headlamp, I simply cannot be sold on a CW bike light anymore :slight_smile: NW FTW!
Sorry, I was not aware of this issue. I use FireFox on a PC and Chrome on my Android phone (tried Firefox, but it was too buggy and frustrating).
-Garry
No problem.
I'm sure it's all Photobucket's doing. :)
I had issues with a few other sites. I couldnā€™t even see my own photos from TinyPic sometimes, very annoying.
Link to the thread with my Convoy M1's intended for helmet mounted use. I compared a build with an XP-G2 vs. a build with an XM-L2.
-Garry
Link to ImA4Wheelr's Custom Mod Thread for my HD-016. My beamshots start at post# 149.
-Garry
Beamshot Comparison between un-modded and modded HD-016. I was in a rush to beat a storm coming, and didnā€™t notice the first shot was way out of focus (I did almost get some shots with lightning strikes in the background!) Also, the original beamshots had a wrong white balance setting and appear more blue than they should (should appear a crisp cool white). My modded beamshots are with the KD driver programmed at levels 2,7, & 10 (I think low is ā€œ2ā€, but I never confirmed that after my accidental reprogramming). Keep in mind the stock light was only driven at +/- 1.4A per emitter and now itā€™s modded to 2.4A per emitter. Original beamshots are only with both LEDs on (no sense comparing single throw / single flood shots).
Modded Beamshots, distance to the two trees is approx. 185 feet (I aimed at the tree to the left). Approx. 275 feet to the house off to the left of the tree.:
Low:
Med:
High:
Wooded simulated bike trail
Low:
Med:
High:
Mouseoverā€™s with original Un-modded Light (Mouse Out=Original, Mouse Over=Modded):
Yard:
Wooded:
-Garry
Hereā€™s an interesting comparison, Nitefighter BT40s on Turbo vs. my modded HD-016 on high (note: photos on different dates):
Yard:
BT40s:
HD-016:
Wooded Setting:
BT40s:
HD-016
Mouseovers (BT40s = Mouse Out, HD-016 = Mouse Over):
Yard:
Woods:
Very similar performance, with the BT40ā€™s having some more throw. (Remember the BT40s is 4xXP-G2ā€™s at roughly 1.0A per emitter.)
-Garry
That BT40s sure washes an area with a nice even light. Seems like a nice candidate for the 90+CRI 219C's when they come out.
This is not criticizing as you take much better pictures than me. The perspective is slightly different on the yard shots. Your much more into the beam on the BT40s as the spill hits the bottom of the picture. The HD the bottom of the spill is about 20% up into the picture. That being said, it appears that the beam of the BT is wider. Sure is nice and even, that BT beam.
Yeah, they were taken on different dates so it was hard to match them up (right now I at least have a spot of "dead grass" where I know to position the "table" (not my photo) to do my shots). I'm surprised they matched up that well, especially the wooded shot! I would have taken shots of the BT40s at the same time, but I was in a rush last night. I almost need a "fake bike frontend" to mount the lights to to simulate in the beamshots (that's going a little far I think; my wife would really question my sanity if she saw that in our backyard!). Perhaps I can at least put something semi-permanent on the ground to mark where to place the light and where to set the camera tripod (and keep record of my tripod heights used to keep that consistent).
-Garry
LOL. You could call the permanent fake bike front end modern yard art.
Of course, if your wife is smarter than you (like mine is compared to me), that won't fly for a NY second.
As much as I like high cri emitters for some things I prefer the sharper contrast that a cooler tint like 1D gives for night trails. That mod sure turned out nicely though.
I've been slacking off on keeping this thread updated. I've picked up one of the most popular and probably best bang for the buck bike lights out right now, the NiteFighter BT21 sold by GearBest (currently only $22.19 which is a steal!). It comes neutral white (3C I think), with very good thermal properties (i.e. mostly solid wall behind the emitter plate) and the full kit comes with a very good battery pack built with BAK cells. It pulls about 2.80 on Turbo (on an 8.4v pack, so 2.8A per LED). It can also be modded with various optics available. The only real issue with it is the plastic mount has very thin plastic where the screw attaches it to the lighthead. I've replaced mine with an aluminum one from DX, but plan to do a custom finned vancbiker gopro mount (see MTBR's Lights & Night Riding forum). The MTBR thread for this light is here.
My Current #'s:
Low: 0.12A
Med: 0.48A
High: 1.26A
Turbo: 2.70A
Modes are L-M-H-Turbo-L-M . . . with off being a long press from any mode. I believe there is a hidden strobe activated with a quick double-click (can't remember for certain).
I don't have any beamshots myself yet, but here are a few pics. I've just finished "modding" mine with LEDDNA 10 degree optics for a tighter beam on a helmet. The stock optics are frosted and I'd guess 15 degree. They've been measured to have significant light loss compared to the LEDDNA optics and others.
Optics swapped with white holders removed:
Stock optics (right) vs. LEDDNA 10Āŗ optics (left):
DX Mount (right), stock (left):
Optics holders trimmed to fit (to help reflect more light back out):
I had to trim the back side of the optic holder to get them to seat down far enough to get the faceplate to seal:
Final Light (yes, front o-rings pushed out a little - the LEDDNA optics don't have that nice indent for the o-rings to seat on):
Will have to update with beamshots. Sorry I won't have before & after though. In stock form the optics work great for bar use; a nice wide swath of light maintaining some decent throw.
EDIT - see post#45 below for beamshots.
-Garry
Nice info. Thanks for sharing. Really like the look of the host. Looks quite sturdy (not counting the mount). Sounds like the UI is very close to what you were seeking before that KD driver came out.
Thanks Garry.
How does it compare to the current ā€œgoodā€ Yinding?
As itā€™s night riding season again, Iā€™ve been making good use of my FrankenDale flashlights.
