crap! we need an EU warehouse!!!
thanks Richard. I appreciate you putting this out there for the BLF community. Ordered the boards and the MMU breakout board that pilotdog reminded me of!!
subscribed and waiting on the higher amperage one also! Kudos to Richard for this fantastic resource. Wonderful vendor.
cant wait for other versions! twenty and 22 mm versions would be cool
For 20~22mm size we already have the LD-29 (about 21mm) which is capable to handle and deliver high current.
i need more than 3a though. 6a would be good. or more
I wouldn't recommend using this with a contact board, as it relies on having a direct thermal path between the ground ring and the pill, either by use of a retaining ring or solder to transfer the heat from the driver. Any intermediate piece, especially another PCB, will limit the transfer to some extent.
Looks great RMM. You know much more about this stuff than me. So I apologize if this is a dumb suggestion. I find that the fly back diode to be a limiting factor in some buck drivers. Maybe the inductor size you are limited to space wise is more of a bottleneck, but it looks like you have room to add a parallel to D1.
Extreme high power isn't the point of this board. An extremely low profile along with programmability and reliability was the design goal; the other board (still to be released) is for higher power.
In a small SMD inductor there is a lot of resistance, and with that resistance comes a lot of heat at high currents. You also have to deal with core saturation on a small inductor like this, although it would tolerate 5A-6A. That is why there is two versions of the board: one for low-profile applications, and another that is for pills with a bit more room for an external inductor that can run more current due to its lower resistance and getting the heat away from the board (and also has a bigger diode). I didn't stick a huge diode on here because it simply isn't needed for what my design goal was (3.5A-4A), is smaller, and is less than half the price of a bigger diode.
Would a copper ring soldered to the annular ring be ok?
[/quote]
I'm sure it would be. That said, if you're patient you'll get a 20mm soon that can do 5A+ with a bigger inductor and diode on board. It will also be slightly more efficient due to the slightly bigger inductor, so if you want to do 20mm I'd wait.
if you’re patient you’ll get a 20mm soon that can do 5A+ with a bigger inductor and diode on board. It will also be slightly more efficient due to the slightly bigger inductor, so if you want to do 20mm I’d wait.
BTW, I am currently testing a few different 17mm revisions setup for more power, but I don't generally release anything that I haven't personally built and tested. I don't have time to support and post on many "WIP" types of threads. The general rule is that if I've shared it, it's actually been built and tested. It doesn't mean it will be perfect, but that if properly built it will work.
If you want maximum performance and efficiency you really need a Coilcraft inductor (XAL series). Their small inductors blow away everything else in similarly sized packages. They are almost three times the price of an Abracon or Bourns, but if you really want a 5A+ 17mm driver with an SMD inductor, I think it's the only way to go.
I ordered from OshPark today so I threw three of these in my cart as well
Also placed an order with RMM today. Richard, please check my note and get back to me if there is a problem with the resistors I’m using.
ill be waiting on a parts list so i no im ordering the right parts :)
I’m sure it would be. That said, if you’re patient you’ll get a 20mm soon that can do 5A+ with a bigger inductor and diode on board. It will also be slightly more efficient due to the slightly bigger inductor, so if you want to do 20mm I’d wait.
Hi Richard, as I read your OP I thought you’re working on a 17mm buck driver which can deliver 5A+ current (with bigger inductor), instead of 20mm isn’t it?
I believe he’s doing both
I believe he is designing 17mm low and high current drivers. It shouldn’t take much to extend the borders for the OshPark boards so he will probably release 20mm as well, but the goal is the 17mm boards as there is more of a need for them.
