So Star is Public Domain, I guess. Thing is, when I started learning I took luxdrv-030b because it’s so small, Star is quite big, and well commented by DrJones. It really is a good avr hello world. And should imho be put in the public domain. But I’ll take a look on Star too now as the code already is public domain.
I don't know if its been tried before (let me know), but here is a way to get extremely low 'OFF state' current (parasitic current, quiescent current, sleep current, etc.). I'm talking about the current used by the driver after it has shut itself down due to Low Voltage Monitor (LVM) kicking in. (Obviously to get zero current just click the switch OFF!) Lowering this current will help protect the cell or cells when the light has been left ON and forgotten.
The amount of current used by a typical 105C driver is very small compared to the capacity of a typical cell, but remember the LVM forced a shut down because the cell is nearly dead, so there isn't a lot of capacity left to run for long before the cell voltage drops to bad levels. With some mods we can drop this current under 0.002mA (2uA). But, we need to do some rewiring and recoding... are you up for it?
To do this we need to tweak the program code, steal the use of Star3 and move the lower ADC resistor, the one going to ground (usually 4.7k in a 105C driver). One end of the resistor goes back to pin7 and the other end now goes to pin3 or Star3. The code now needs to be changed to turn Star3 into an output, and set it Low. This reconnects the resistors just as normal but also allows the ATtiny to turn this pin Off by setting it to an input when the LVM kicks in. This opens the current path through the resistors saving over 100uA. If you were using Star3 to select memory, or the like, then you'll now have something else to do in code.
I've listed some typical currents used by different circuits. These depend on battery voltage and are roughly as follows:
ADC resistors = 3V / (22k + 4.7k) = 112uA
This mod reduces the ADC resistor current draw to zero.
OffTimeCap resistor = 3V / 470k = 6uA This current is already zero if a resistor is not used with the OTC
Change code to set this pin low before going to sleep, no need to keep the cap charged when "OFF".
ATtiny13A = 2uA Assuming Power Down Sleep mode with ADC off
Can't get much below 2uA...
Zener Mods = 6V(batt) - 5V(zener) / 200ohm = 5000uA Changes with different resistor
IMHO multi-cell lights should be done with low current LDO regulators (like TPS71550) rather than zeners. But I understand completely that these mods work perfectly well, they're just not as low current as a regulator. TPS71550 draws 3uA. My latest 2 cell driver now sleeps at less then 5uA.
Edit:This mod is not recommended for multi-cell setups as the voltage on the ADC pin will rise above the MCU supply voltage. This may/will draw current, and defeat the purpose of this mod.My 2 cell mod seems to work probably because the LVP point is very close to the MCU supply voltage.
I'm a hardware guy, so I don't feel comfortable telling you how to tweak the code in your particular driver to do these changes. (I had trouble trying to program a pin to be an input...) enough said. These are the changes I made to ToyKeeper's TK_OTC.c, it's nothing special even an old hardware guy can figure it out! Thanks TK! :)
#define STAR3_PIN PB4 // Low end of ADC voltage divider resistors
#define STAR3_DIDR ADC2D // Digital input disable bit corresponding with PB4
Added this to ADC_on()
DIDR0 |= (1 << STAR3_DIDR); // disable digital input on STAR3 pin to reduce power consumption
DDRB |= (1 << STAR3_PIN); // Set to Output
PORTB &= ~(1 << STAR3_PIN); // Pull low end of Voltage divider to ground DDRB &= ~(1 << STAR3_PIN); // Set to Input (without pull-up) oops
Added this to ADC_off()
Added this just before Set_Sleep_Mode
ADC_off(); //ADC off
PORTB &= ~(1 << CAP_PIN); // Drive Cap_pin Low
Cool more dummy prof protection is always welcome, when you want to give lithium lights to less hyper aware individual.
Does this work on all attiny13a drivers & not only on “typical 105C driver”
like the fet+7135 driver for example because that one don’t have any “stars” or am i missing something vital here?
I think this can be adapted to any 13A driver because typically pin3 (Star3) is unused. Unfortunately, that pin is not in a convenient location to make this mod easy (but where is the fun in easy?). Even E-switch drivers can benefit from this mod. In fact they would have the most to gain because they are always drawing some current. But I don't have any to test this out on... Likewise, any driver using any micro-controller should be able to adapt this technique to reduce current.
Somewhat off topic…
Does 112uA = +/-1A per year?
So a typical 3000mAh 18650 would drain a third of its capacity in a year with a 112uA parasitic drain?
Anyway, to sum it up. Tido use GPLv2 for BLF-VLD and JonnyC use Public Domain for Star. And then you use GPLv3 for blf-a6. Those are the ones that you can safely use then.
With CC-BY-NC-SA, you should be safe to use the code for your own use, and to publish modifications you make of it, as long as it’s under the same license and you give credit to DrJones. Selling a light with a version of that software is likely not allowed, and as a guess no selling of it is DrJones intent. I don’t know of a software license that allows that sort of use, CC-BY-NC-SA does.
From some random page I pulled up with a quick Google search:
AFAIK the GPL also allows commercial distribution, and doesn’t specifically require attribution. TK can tell us, as she works with this stuff all the time. But, I doubt those things would be hard to add if they were important to you. I think the GPL does require re-distributors provide a link to the unmodified original code, though. That would probably count as attribution. Like I said, ask TK.
Well yes, your math is correct (if you ignore self discharge), but why would the light will be in LVP mode if the cell has a full charge?
This mod helps protect the cell once it is depleted. At that point there is very little reserve capacity to feed that 112uA drain. Dropping that current to 2uA gives you 50X more time to realize that you left the switch ON. Is this a solution to all the world's problems? No, but it is a small step in the right direction.
The GPL requires re-distributors to provide the source code for whatever they are distributing. If they modified it, they need to include their modified version. If it’s unmodified, they should include the original version. Aside from just guaranteeing that everyone can use and mod it, it is also intended to make sure that people share the improvements they make.
This can be inconvenient for vendors though. It would mean, for example, that if RMM sold drivers with the BLF-A6 firmware, he would need to include a link to (or copy of) the BLF-A6 source code or at least provide it to anyone who asked for it. With the public-domain(ish) STAR firmware, he doesn’t need to do this.
Some people prefer BSD-style licenses, which make virtually no demands on anyone. One can modify BSD-licensed code and sell products using it with no need to share their code or improvements. In fact, this is where much of Microsoft’s code came from; it’s based on old BSD code. There is an ancient and ongoing debate about whether “share” or “share and share alike” is more “free”.
Regardless, I’m happy about contributions people share under any open license. You’re helping people you may never even know about.
It sets the CPU clock speed and pulse generator options. It’s a little easier to read the parts of STAR which do the same thing, or the attiny13a reference manual has full details on which bits do what.
The most common options are whether to use “fast” PWM (18.75 kHz sawtooth wave) or “phase-correct” PWM (9 kHz triangle wave), and single channel or dual-channel PWM. In single-channel mode one can also select whether to use variable PFM (pulse frequency modulation) or stick with the default speed.
I started on some ideas I had knocking around in the back of my head, and ended up with a FET+1 firmware which works like the diagram below… I’m curious what people think. It basically has a regular mode group, a secondary group for the most useful blinkies, and a tertiary group for a full set of blinkies.
ToyKeeper is one of our most valued players. He She is one who is nice enough to share with EVERYONE. :bigsmile:
Puts a lot of effort into this for us. A BIG thumbs up for him her!
