The one I got with a solid pill upgraded very nicely with a PC Rebel. Never got another one, from anywhere.
The other half dozen I have from the lottery, I’m starting to hand-carve copper disks to drop into the hole behind the emitter; they raise the LED closer to the lens so mess up the perfectly focused image a bit, but the zoom still makes a tight enough spot — but they seem to carry the heat off to the body adequately, using the “SK68” driver in various versions that Cerealkiller has made for me.
I do like these little #3s a lot. If only I could get more with solid pills (sigh).
http://www.fasttech.com/products/1612/10001750/1127402-12-aaaaa-1-mode-800ma-linear-booster-led-flashligh Looks similar to the #3 stock driver, I wonder what would happen if I replace that R270 with a lower rated one - or bypass it completely, idk.
See this thread Noob needs help with #3 XPE Q5 modding for other modding considerations. Heat management is my last concern, I still have to find a way to get output high enough first, with 1 or 2 1.2V AA that is. No drivers, at least none to decent prices (I think sandwich shoppe has one around $15) for 2 AA. Maybe I could use two drivers, like in Dual driver mods for single XM-L2's (edit: just realized that’s a bad idea, after reading some more about the XPE. Guess I’ll aim for 0.800-1A max.)
i have this and compared to the Sipik sk68 and ALL THE CLONES are better then this
the biggest failure is the clip its too weak and is not attached it just slips (loosely) around the battery cover so it totally interferes with changing the battery
also all of them are blueish
and they are not as bright at all
the beam pattern is a lot smaller
trust me when i say this is a cheap chinese toy and fails in every way compared to the sk68
i for one am not happy and hope this design dies quickly
and the cloners stick with the Sipik sk68 to clone even the worse sk68 clone i have is better then this
Actually I MUCH prefer these little zoomies to the SK68.
The SK68’s unwieldy shape with lots of crenelations is uncomfortable for pocket carry. These little zoomies are half the size but virtually the same brightness. They also have a much smoother more-streamlined shape that won’t tear up a pocket.
Performance between this type of light and the SK68 is quite similar. They have a fairly wide flood. Throw is very similar to a SK68, though the beam is narrower due to long focal length lens.
I agree the ring-clip interferes with battery changes. I removed it from mine. There’s also a variant with a slightly different bezel design that has a slip on clip that doesn’t get in the way.
You can drill through the side of the tailcap, carefully, and make a suitable hole for a split ring.
Much nicer than the stupid little metal clip.
I sure wish I knew a reliable source for solid pills for these #3 zoomies.
They’re decent mod lights even with the hollow pill — I stick a copper disk into the shelf, and put a 10mm square board with a PC Rebel on that.
They’re a pleasure to give away to people — passing on my older Energizer lithium primary AA cells when I refresh the batteries in the earthquake cache.
I got one of the gold ones. It’s at least as bright as a SK68 but thinner and easier to pocket. Not as thick or heavy so it’s not built as well but the SK68 is a beefy light. This light makes a good little 1AA cheap alternative. I’ve had mine for about a year with no problems. I like it.
I own a bunch of these from various different brands.
In mine, the star is either 16mm or 14mm. The ones using a 16mm star have a hollow pill. The 14mm ones have a solid pill. It’s not that hard to file down a 16mm noctigon with a handfile so it fits the 14mm slot.
The driver is 14mm. A 15mm driver from mountain electronics fits easily with a minimal amount of filing at the edges. A 17mm Nanjg 105c can fit as a floating driver below the pill, but it takes a heroic amount of filing and can easily result in a destroyed driver.
Lottery! I have exactly one with a solid pill, and it came with a 16mm emitter; I have going on a dozen with hollow pills, most of those with sort-of-15mm emitters that are probablyjust cut down and filed down. Those are the ones with the rough cut rectangular notches for unscrewing the pill that look like they were put in with a chisel ….
Sure would like to find solid pills reliably. I put in one 10mm square Luxeon PC Rebel board and it fits perfectly on the solid pill — leaves the wire holes unblocked, and self-centers with its corners right at the circumference of the cutout. (I’ve stuffed 16mm copper disks from Etsy into the holes on other ones.)
Going by how the tailcap and the crenelations in the mid section look, I’d also say the gearbest is a hollow pill 1-mode.
Btw. the AE 3-modes are (subjectively) slightly brighter. You could buy several and try to pencil mod them to 1-mode (several capacitors on that PCB) if you don’t mind the effort.
They separated my order so I received only silver, black is still in transit. You’re right, silver has 3 mode and it doesn’t work on AA battery but it works on 14500.
Also led doesn’t look like XP-E and is less brighter then my SK68 from Bangood.
Other than that; body, zoom and switch looks ok. Its much lighter and smaller then SK68 and feels better in the hand.
Bought one of Ebay ; new record in blue tint and low lumens.Tailcap tread did not fit my extensions.
With Cree it would have been a nice flashlight.
A year ago I got two that where weak but OK.
