Wow, interesting... Not sure if the Studio IDE set that somehow by default. It's in the Compile "Miscellaneous" settings. When I create new solutions/projects, I simply copy a previous to begin with.
I was thinking about doing it byte by byte but thought it would be too slow so I went with a 8 byte array instead. I got plenty of space in ram anyway but I may switch later when my flasher arrives. But i donāt want a noticable boot time in my driver.
Edit: Using an array was a bit tricky with a weird pointer to the eeprom adress. Must get my flasher to confirm I got it right.
The attiny13a is running at 4.8 MHz. It only takes a few clock cycles to check each eeprom byte, and there are 64 bytes. Letās say it takes a dozen cycles each; thatās 768 cycles, which should take about 0.16 ms total. The data sheets suggest an array might save about four clock cycles per byte, but itāll still be roughly 0.1 ms.
Can you feel a boot-up difference of 0.05 milliseconds?
In general, yes, phase-correct PWM is a good idea on the highest level. It doesnāt usually make any noticeable difference, but itās nice to make the code default to phase-correct to account for the few cases where it matters. I donāt think the hardware has a default; you have to explicitly tell it to generate pulse waves because those pins can also serve other functions.
Well, the timer is set to arround 1.5minutes- then it ramps down to 50%, the FL body gets only warmer this way ā¦.plus when its mounted on a weapon it lights for usualy 10 seconds tops- i use simple momentary on self made remote switches, made from thick Cu pads: found that those are most reliable, especialy with all that forest fog and moisture
The 7135 thingā¦ā¦you might be right, i have to try the 024 version out then
Once again, 10x for that 1mode version, i waited for this long time
Most likely not. But, you can have all the mhz in the world, if itās slow reading from eeprom itāll still be slow. Look, Iām not saying itās too slow reading byte by byte. I thought it was faster reading 8 byte blocks but if it works reading byte by byte that is a simpler solution.
Ish. I normally use phase-correct on moon and turbo, and use fast for everything between. The pulses are longer with phase, which makes moon more stable (drops less with voltage).
But if it doesnāt bother you, you could use phase everywhere. I donāt like the whining sound or visible flashing, but not everyone is sensitive to those.
Getting rid of buzzing pwm modes are my main motivation for writing my own firmware. But was thinking about something else. How do the different sleep modes work? SLEEP_MODE_IDLE just seems to be doing more or less nothing. Iām more curious about SLEEP_MODE_PWR_DOWN though. Does it turn off the output? If you run a special mode like ie strobe it could be a bit tricky to turn it off manually otherwise. You only got a few bytes to play with so would be nice if output is turned off automatically when going to SLEEP_MODE_PWR_DOWN.
TBH, I havenāt really optimized much for sleep mode. I have some relevant patches waiting for me to merge and test, but I havenāt done it yetā¦
In sleep mode the PWM counter stops, but I havenāt specifically tested to see what that does when I donāt set it to zero first. I expect the emitter would stay on if itās not turned off before entering sleep (which is a trick I use for the standby light on my Roche F6, but first I set it to a special non-PWM low mode).
Interrupts can wake up the MCU from sleep mode, if they are enabled and a relevant event happens. Touching the e-switch is one example, or the watchdog timer can do it too. So for low-power shutdown itās usually a good idea to disable interrupts too. On e-switch standby though, at least the switch interrupt needs to stay on.
Hey thanks for the tip. By adding c99 to the makefile and using inline for a few functions that only run once I managed to save 40 bytes. It looks like c89 is the default you get. Using c11 didnāt change anything for me though.
Sorry, Iām still a total noob at this. Is this close to what would need to be done? The purpose is for my XinTD X3, i want to have one mode group for 18650, and one for use with 3x alkaline AAās. So I donāt need LVP for the AAās.
What is the lower PWM limit where you switch between phase-correct and fast?
Interesting. I never looked at the E-switch versions of Star. I coded my own E-switch routine by changing the watchdog timer to the fastest and have the switch test in my main while(1) loop. It may have made the logic pretty easy but I guess itās not a power efficient way of running things as my entire main routine with voltage monitoring and all gets executed a whole lot more. Has anyone done any tests? Or maybe this stuff can be found in the datasheets, havenāt looked at MCU power consumption at all.
Close. You used a preprocessor ā#ifā, which runs at compile time. What you need instead is a regular C āifā which runs during regular operation.
if (some condition) {
do this;
Other than the syntax, I think you nailed it. The whole LVP clause just needs the āifā around it so itāll only run in one mode group.
I use phase for moon and turbo only. The threshold is whatever level I need for moon. Usually I calibrate this per-light, using whatever gets me closest to 0.3 lm. However, if the two nearest phase levels are too far apart and a fast PWM mode gets closer, sometimes Iāll use fast instead.
I doubt the MCU power consumption is a significant factor when the main emitter is on. I mean, it normally spends most of its time in busy loopsā¦ so I doubt it matters if you check things more often.
As for e-switches, Iāve been meaning to write a new e-switch code base from scratch. The approach used in STAR works and is compact but makes it relatively difficult to handle or map events. Iām hoping instead to keep an event queue where actions can be mapped in more intuitive ways. For example, āif (events_eq(triple_click)) { blah; }ā. This might require a bigger MCU though; my early experiments ran out of space quickly.
After using cypreus2 on a real light for a day, I decided the hidden modes were in the wrong order. I updated it to make things a little nicer by default. Hereās the new interface:
I still have 70 bytes left to do something with, but Iām not sure what. I know I donāt have to fill all the space, but maybe thereās something worth adding? I might be able to fit soft-regulation for moon, to make it more stable at different voltagesā¦
BTW, the reason it has two turbos is because itās running on a light which goes well beyond the sane limit for power in its size ā 10 to 15 amps in a little 18650 tube light (2200 to 3300 lumens, depending on the hardware). Thatās the same as a Skyray King or Supfire M6, only in a much smaller host. This is configurable in the firmware, of course, but I donāt want to melt my nice new hotrod.
Correct me if I'm wrong but I believe that chart shows the wake-up sources from the various sleep modes, and doesn't imply that all other systems are disabled.
This is an excerpt from the ATtiny13A datasheet (doc8126):
"7.4.1 Analog to Digital Converter
If enabled, the ADC will be enabled in all sleep modes. To save power, the ADC should be disabled
before entering any sleep mode. When the ADC is turned off and on again, the next
conversion will be an extended conversion. Refer to āAnalog to Digital Converterā on page 82 for
details on ADC operation."
