Hhmm - I gotta re-check part prices again then. Maybe I was just spot checking the MCU's, FET's, diodes - Hhmm: I see the ATTiny13A's are definitely cheaper at Mouser....
Yep, can't think of much I can do with a buck driver at 17mm. I have no P60 tube extensions, but think I got 1 or 2 for Convoy C8's, and pretty much all my 2S cell lights use a bigger driver. The limited 18350 capacity can't justify converting a 1 cell 18650 light over. Also 4A is very limited if driving 2S cell triple LED lights, and converting the 3 LED's to parallel - obviously 2S cells driving 3S LED's won't work with a buck driver - boost is needed.
One group that may be very interested in this driver is laser enthusiasts. Especially, if it provides pretty clean power. Most laser diodes need much less then 4amps of power and some have fairly high Vf's. They are always in search of a good boost and buck drivers. If you don't belong to Laser Pointer Forums, there are some senior LPF members here on BLF. Maybe one of them can help introduce you there to get you some street cred.
I've looked at a few drivers over there before. I think they'll be surprised to see that none of the IC markings have been sanded off and the files and information are available for free.
What does "HP" stand for? High Performance. I've got one running at 5.5A in a UF-1405 right now and it seems to be holding up well so far. I ran it on 100% for 7 minutes straight and it didn't burn up, so I think there's a good chance that it will hold up in the long run. That light finally runs like it should have from the beginning. A bit more testing is needed, but I think that is the direction I'm going now. The same design will be able to be used from 1A all the way up to 5.5A in 17mm by just changing a few components on the board.
Also, I was able to build and test a 20mm. It will be available soon. That one can also do 5.5A (or maybe even more...haven't tried it yet. The only place I'd want more would be in powering a triple or MT-G2. For an XM-L2 5.5A is sufficient).
Different PCB, but only slightly different. Two diodes instead of one with an extra input capacitor pad.
Also, you need a Coilcraft inductor for this one, and it needs to be in a host with a pill design that is big enough and beefy enough to carry the heat away from the driver. I wouldn't stick this one in a P60 or something small.
We are really pushing it thermally with these tiny components. I have only run this 5.5A through a single set of 26650s so far, so it really needs more testing. I would hate to have them all start failing at the two hour mark. The regular ones have seen 30+ hours at 3.5A and 4A inside of an actual flashlight, so I know that they can work.
I've thought about unmasking a bit more of the copper on the thicker heat carrying traces so that they can be loaded with solder to reduce thermal and electrical resistance. Every little bit can help here. A 4 layer board, and a board with thicker copper would also provide thermal advantages if set up correctly, but those add to the cost significantly. Adding an optional bit of solder does not, so I am going to do a few tests to see if critical component temperatures change significantly with solder loaded copper planes.
Ok. I got my pcbās for the 17mm, but I didnāt realize the parts are so pricey so Iāll have to wait a little bit to order those. (Thanks for putting up the parts kit listing)
I was going to only do about 3.5-4amp in my L2m, but eventually I do want to get one of the higher performance versions for my own uf-1405.
The parts list and shopping cart link is in the OP. Obviously the prices go down as you buy more parts, so you can figure it out yourself by increasing the amounts in the cart.
Lol. Maybe with a DTP copper multi layer MCPCB board... or maybe we could install a sodium cooling system, like those used in nuclear power generation.
Thanks. I think the price seems reasonable, my problem is when I think about trying to assemble 50-100 pc of this ( about what I would need for production runs) my head starts to swim. Its all I can do to get the single sided FET drivers together LOL!
Richard I hope that this driver takes off well enough for you that having some fully assembled boards done in large batches is feasible. If you get the inkling to have a batch made in China let me know, I could take a few off your hands
has anybody built one of these drivers yet? I almost threw mine away as I didnāt realize the parts from RMM were taped to a sheet of paper
I should have my toaster oven today so I might try this weekend. ADC values can be calculated from your google sheet, right RMM?
I donāt have the parts in front of me so I donāt remember what R1/R2 you sent me, but I imagine itās the standard calculation as seen on the google sheet when I have the R values.
I didnāt build them, I grabbed the 2 RMM had on his āgarage saleā listing.
RICHARD,
Is it just me, or is the mode change ātapā very short on these.
When I change modes, I have to tap super fast sometimes. My normal tap is too slow for it part of the time.
Mine have GuppyDrv, if that matters.
Just had a thought, maybe I got something on the memory capacitor. Iāll check that tonight.
The tap is indeed different than what you're probably used to. I had to make it fast enough for guppydrv to work, so yours are pretty fast. 19.1K gives you a slower tap than 4.7K does. I built the first ones with 19.1K, but it is a little too slow to consistently be able to get into guppydrv's mode select mode, so I started putting 4.7K on there. ~10K would probably get you into an "in between" zone. You could get approximately 10K by stacking two 19.1K resistors.
No matter what, the mode switching isn't going to be 100% the same as a "normal" drive because here we have a lot more capacitance and the MCU is being powered from the buck IC's output.
I never thought of it that way.
It works fine, just different from what Iām used to as you said.
I just wanted to make sure I didnāt mess something up.
(I have a tendency for doing just that)
I have GuppyDrv on many of my lights, and this made me wonder for a minute. Since Iāve played with it for a while now, its no big deal.
I may do a basic review in a couple weeks after I get the other one in a light and get some time with them.
I dont have much by way of test equipment, so when I say āBasic reviewā I mean basic.
I've never done one with a toaster oven, but you're going to have to at least do part of it with something else, because it is double sided. Make sure that there are no bridges on the MCU and buck IC pins, that they all have good connections, and that the buck IC has enough solder underneath the center thermal/ground pad. I generally like to do this board with a hot air gun so I can watch and reposition everything if needed, as well as fixing bridges and adding solder while things are hot. I would rank this board as being a step or two more difficult to properly assemble than a normal FET driver.
I sent you 36K and 4.7K resistors. I'd put a little more spread between the LOW and CRIT values than what you normally would with a DD/7135 driver, unless you just want it to turn off as soon as the cells are low. The big difference here is that the amp draw on the batteries increases as they drain, while the DD/7135 drivers are putting significantly less draw on the batteries as they get low, so if you want it to step down levels before going all the way to the bottom and shutting off you need to use a bit higher LOW value.
