Daily Deals for the next week. Only at www.andrew-amanda.com
One of these weeks I’m going to weaken and get the EA41
you won’t be sorry. I want it, but I got the EA4W for like $36. It is one of my favorite lights! Only drawback is no moonlight mode, which the EA41 has. GET IT! Great price!
Ordered s20R. Good price. Thank you!
No, thank you………… thank you.
I would love to see you roll out a deal on a Nitecore MH20…holding out for it…
I’ll see what I can do. It might still be too close to the release to do a deal but I’ll mention it for sure.
-Zane
I’m looking at the EagleTac D25C2 Clicky with XM-L2, I see you’re showing two versions but the specs in your listing are very confusing: both show XM-L2 U2 in the title, but neither show that in the description (one shows XM-L U2 and the other XM-L2)
According to EagleTac’s web page they make only 2 versions with XM-L2:
XM-L2 U2 (CW)
and
XM-L2 T6 (NW)
Please let me know what LED the 2 you have listed actually have:
LED: CREE XM-L U2 LED —- Turbo: 741 lumens http://www.andrew-amanda.com/catalog/product/eagletac-d25c2-clicky/
LED: CREE XM-L2 LED —- Turbo: 850 lumens http://www.andrew-amanda.com/catalog/product/eagletac-d25c2-clicky-xm-l2/
I’d also like to know the tint #’s and K temps for each, since ET doesn’t publish those specs. (1A, 2B, 3C - 6000k, 3500k, 5000k Etc.)
Loving the new armytek barracuda and it’s 1x18650 tube option. Sad that shipping to Canada isn’t so cheap and easy
I love their daily deals. I just picked up the Jetbeam WL-S4, from them, on the 8th of this month, and am really loving it!
WL-S4 on the right
Super powerful light, with a wonderful beam tint! First rate service from Andrew/Amanda.
Thanks, you guys!
get some help
Beam0, sadly we only have the D25C2 XP-G2 in stock currently and I don’t believe we are planning to restock the XM-L2 models of this light. Since we don’t have any in house to test or instruction manuals laying around, we know just as much about the specs as eagletac has posted online as well. Sorry I couldn’t be of more help.
mizjif, use the “make an offer” option on our website. Andrew might be able to cut you a deal that will make the shipping less painful.
and david57strat, thank you for your business! Much appreciated and quite an extensive collection ya have going. Cheers!
-Zane
@ djburkes, I tried to get the MH20 into the deal of the day. Honest I did……. but we have to hold off for a tad longer.
I purchased a D25C from Andrew-Amanda for about the same as your current weekly-deal offer.
Although I live in London, it was intentionally purchased for delivery whilst I am in Florida to help with delivery in the US.
As expected it was delivered promptly and received yesterday (Friday) morning.
I eagerly (or should that be eagle-y?!) opened the package to find a well protected and retail boxed flashlight. The light itself was packed inside the included pouch, with the clip already attached.
There are a few minor abrasions on the head and body where they join - I suspect this is simply from the exposed rear of the popper inside the pouch rubbing against the light during transit. The XM-L2 CW emitter is ever so slightly off-centre. Subtle enough that most people might not even notice, but we’re all obsessive BLF’ers after all, are we not!
I placed a freshly charged and proven RCR123A (nitecore 166) into the light and tightened the head back up. Switched on… nothing. On/off/on/off… nothing. Screw/unscrew head; loosen/tighten head… you guessed it nothing.
Tried with a band new primary CR123 with the same result (or lack thereof), and feared a DOA light. Then all of a sudden LIGHT!! However relief was short-lived and temporary as it still intermittently fails entirely during mode switching using tail switch or head.
I cannot pinpoint what is causing it to fail, but very slightly flicking the side of the light sometimes causes it to illuminate if the switch is already on. Then changing modes causes it to switch off and fail all over again!
Unfortunately I return home to London on 31st, and cannot get hold of Andrew-Amanda until after the memorial weekend.
Is there anything I could try on the light to fix it or get it working? Has anyone else here experienced similar with an Eagletac D-series?
I know from reviews here that this is not typical of A-A supplied goods, nor Eagletac quality. I sincerely hope Andrew-Amanda are able to kindly assist with resolving the issue.
Regards,
Adam
Hi Adam, first thing I would do is to clean all contact surfaces and threads. yours is a twisty not a clicky right?
Thanks for the advice; the D25C I purchased is the 2014 Ti titanium model which does have a gitd rear clicky.
The modes are intended to be in two groups. Fully tightened head is group 1, loose head is group two. Individual modes in each group are selected by the clicky.
As you suggested, I checked and cleaned the head contact. This is a copper section of the pill (screw & +’ve contact) which does make good contact with the button-top cells and body threads. The tail clicky is a spring contact. This has not produced any better results unfortunately!
I fear it is just a bad case of being unlucky, and perhaps the clicky is simply not functioning properly.
Also, I don’t want to mess with it too much so that it can be dealt with properly by the retailer when they are back to work.
