“Tedious” sums it up nicely. IMNERHO the PhotoBucket part would have to be the worst. Clicking through until you get to the actual picture so you can use the actual URL…
Yes I build out the pic-heavy posts in a .txt, then Select All, Copy, & Paste into the Comment: box.
You can make a “generic” .txt file with keywords to be replaced. E.g. you could use “PICURL” for the picture URL (i.e. the URL from PhotoBucket) and “THISCAPTION” for the Caption part, then use the Edit menu Find & Replace function. This way all the little markers and size % and delimiters are left intact. After you’ve first Pasted the bulk into the Comment: box, touch-ups and edits aren’t so hard to do.
It’s not like anyone in the 21st Century is ever going to make this “easy”…
You can avoid all of that by going into Photobucket > Settings > Privacy and unchecking File Name Scrambling. Then you can predict the URLs based on the filenames that you upload. Another useful option under Settings > Albums is to turn on Easy Linking Mode. If you go that route, I would also suggest setting the sort order for Albums to Alphabetical by Filename.
What is the URL of the photo? I can’t get “dropbox” to reveal it. Not a dropbox customer/fan, so IDK how they work on your end.
It only matters what the URL of the photograph itself is, not which Server is holding it, nor on what “gallery” or other page that Server shows it to you. It won’t work if that Server is trying to use its “free” Service to make ‘click-money’ & has some krufty kode to prevent showing the actual URL of the photo. Some of the “popular” image hosting sites make it quite difficult to get the address of the image itself and if you’re not willing to dig into their middleware to find Just The URL For Your Image, it’s not likely that anyone else will be either (that includes the authors of the middleware used to run this forum). Sorry, Real Life crashes down in a flash sometimes.
There’s nothing odd about it. It’s how the WWWeb works. Sorry if no one told you that already.
When you add an image to a post here on BLF, the ONLY thing you need is the URL of the actual image itself, not the host’s “doorway” to it, nor any other “gallery” nor “album” nor page nor whatever else the host throws up in your way. If that URL doesn’t end in “.jpg”, “.jpeg”, “.gif”, “.png”, or maybe “.bmp”, it cannot possibly be made to work (unless you’re willing to code up some Forum Middleware for the Admin to use…)
Not to be snooty, but this has already been covered pretty thoroughly in this very thread, BTW…
So when quoting a user who posted an image using a different input format that yours, unfortunately the image won’t show up unless you adapt the quoted code to display the image.
FYI, to post pictures from your Photobucket account, select the photo in your Photobucket account and you will see the following in descending order on the right side of the photo:
Email & IM
Direct
HTML
IMG (this one is the URL option)
Select “Direct” by clicking once on the word “Direct”. You will notice immediately that “Direct” is dithered and faded and the word “copied” shows up to the right of “Direct”. This means the Direct link has been copied and you can now go back to the BLF editor and paste it into the correct spot (the BLF editor will bring up an image maker when you click on the sunset picture icon as directed at the very beginning of this thread).
I made the mistake of selecting “IMG” since I thought we needed the URL link but that didn’t work for me so I started to click on the others and “Direct” worked for me.
Below the comment box for responses you’ll see the words “Input Format”. Click on it and pick “Advanced Post Editor”. Then you’ll see the term “Disable rick-text” that toggles when you click on it.
Boy, this is all well and good for all you tech savvy younger folks but it sure is convoluted for us older technically challenged people.
Why can’t BLF just have a button that says “add photo” and it accesses your photo library and you pick what pictures you want to include? Almost every forum nowadays has this simple way to post pictures.
