I’m ready to pull the trigger on one of these, but which one should I get?
Only decent light I have is a Acebeam K40M and a Skyray 8 (if you consider the Skyray as decent).
I love the acebeams. I like this light because of the brightness and the smaller form factor. Would like to have a bit more flood than the acebeams without losing much throw. For reference I don’t mind paying up for the XP-L’s but my guess is that they are going to add more flood and the throw may not be as good as the XP-G2 1D.
Let me know what you guys think. Will probably order one today based on your recommendation.
I would personally recommend the S2 1D dedomed version, it has good throw, also flood.
But the M43 is not ready for order now as we are still processing some of the old orders.
The sales should be resumed in a week time, but I’m not sure how much time the stock will last.
As we will close the sales any time when current stock is out.
And the assembling time for this little beast is quite long, every detail should be taken care of….
I would love to see a much simpler UI. Simple as in click one = low, click two = medium, click three = high, and no strobe.
Also why not allow pre/back orders? I dont follow the forum regularly so checking back to see if I can order something isn’t a good option for me. I don’t mind going ahead and placing the order and if it shows up 3-5 weeks, that will be fine. I think most consumers would be in this boat.
many years ago a pastor in town was going to start a church. Before he did, he went door to door to door asking the people what their priorities would be for a church. Then they built the church and operated it according to the poll results…
Just wondering out loud what Hank had in mind for the M43. Was it a light he wanted? Was it a light he thought the masses wanted? Is 300 all he plans to produce? Sufficient profit?
by the way, I’m like that previous poster and like the light as it is
I think someone at fonarevka answered about the ramping thing already, saying it would be too hard since the light uses like three different power circuits or power algorithms or something and it wouldn’t change between them smoothly. Something like that anyway. I recall something about ramping not being feasible, but then I wonder how it manages to do the “soft start” thing and smooth changes between levels.
As for ramping though, a pretty simple UI can work well. Click once to turn the light on or off at the last-used level. Hold while on to ramp, release and hold again within a second to turn around and ramp the other way, or if it was released for more than a second it can keep ramping in the same direction next time. Add in a couple shortcuts like double-click from off to get to turbo, or hold from off to get directly to moon. A light with this much range would probably look pretty smooth during ramping using 128 to 256 brightness steps with a total ramp time of maybe 3 seconds from one end to the other. And with battery status on the switch LED, I think that’s all it would need.
