I would love to see a much simpler UI. Simple as in click one = low, click two = medium, click three = high, and no strobe.
Also why not allow pre/back orders? I dont follow the forum regularly so checking back to see if I can order something isn’t a good option for me. I don’t mind going ahead and placing the order and if it shows up 3-5 weeks, that will be fine. I think most consumers would be in this boat.
many years ago a pastor in town was going to start a church. Before he did, he went door to door to door asking the people what their priorities would be for a church. Then they built the church and operated it according to the poll results…
Just wondering out loud what Hank had in mind for the M43. Was it a light he wanted? Was it a light he thought the masses wanted? Is 300 all he plans to produce? Sufficient profit?
by the way, I’m like that previous poster and like the light as it is
I think someone at fonarevka answered about the ramping thing already, saying it would be too hard since the light uses like three different power circuits or power algorithms or something and it wouldn’t change between them smoothly. Something like that anyway. I recall something about ramping not being feasible, but then I wonder how it manages to do the “soft start” thing and smooth changes between levels.
As for ramping though, a pretty simple UI can work well. Click once to turn the light on or off at the last-used level. Hold while on to ramp, release and hold again within a second to turn around and ramp the other way, or if it was released for more than a second it can keep ramping in the same direction next time. Add in a couple shortcuts like double-click from off to get to turbo, or hold from off to get directly to moon. A light with this much range would probably look pretty smooth during ramping using 128 to 256 brightness steps with a total ramp time of maybe 3 seconds from one end to the other. And with battery status on the switch LED, I think that’s all it would need.
Remember, this is a boost converter. It doesn't use PWM dimming like what you're used to seeing and it most likely changes modes by changing the feedback network, meaning that it has a finite number of modes. This is how all of the big multi-mode boost drivers I've seem work, so it isn't as simple as just programming PWM values into the controller. The soft start and smoothness between modes are just part of a big booster's nature. You see the same effect on the TK75.
Talk about fast shipping! I got the XP-G2 S2 D-D version. What a great light. UI 1 is simple to learn. About the same effort as a learning the Zebralight UI. Looks like my S6330’s stocky brother. Turns out that stocky brother has a lot more muscle! Now I just got to save up for the Nichia version.
