Yes, in C arrays are passed as a pointer to the beginning of the array. If you want to know how big that chunk of memory is, you need to pass the size too.
Also, this means that the symbols for arrays and pointers can be used pretty much interchangeably. The syntax of āarray[3]ā is basically identical to ā*(array + 3)ā. Take the pointer, add three of whatever its size unit is, then get whatever is at that location in memory.
Lets just say that I found that out the hard way. Usually I just go by the āif it works donāt try to fix itā philosophy but when you only got 1024 bytes you must code as efficient as possible too.
It works but Iām not really sure I got it completely right though. The rest of the multi group code I got to work directly (didnāt think that would happen). Not sure itās the most efficient way though but so far so good. Also, I canāt really see the point with battery monitoring (if you run out of juice just pop in another one :laughing:. I only kept the power down stuff and got rid of the low mode. Turbo timer I can see that it can be useful with high power DD drivers though so I also added that.
One effective way to deal with array issues in C is to use the Pascal approachā¦ make it one word bigger than necessary, and use the first item in the array to store its length. Another way is to make it one word longer and put a null at the end, but that means you canāt store any other nulls in it.
Or if itās hardcoded at compile time, use āsizeof(myarray)ā to get its length. But that only works for hardcoded arrays and only when the original symbol is referenced.
Yeah I managed to fix the problem with sizeof as my arrays are hardcoded compile time. But I did read up on the things you talk about too. Stackoverflow has tons of answers on just about any possible coding problem. But now I ran into another problem, _delay_ms() only takes compile time constants as value! What da heck is up with that? I was thinking about making it possible to set strobe frequency at run time but now I donāt know if that is even possible to do with just a few bytes.
That's the nature of standard _delay_ms(). I replaced it with my own approximate delay function, which fixes that problem and also saves a couple of bytes. See TheStar.c in the repo.
Ok, itās not exactly a bug but hereās what I found. The _delay_loop function runs in software and doesnāt work reliably if you use a wdt. But I found out that _delay_ms runs on a hardware clock so I switched to that but it didnāt work anyway. So I was just about to throw in the towel when I realised that I donāt really need 1ms resolution so I tried with 5ms instead. And bloody he it worked. So now I can set the strobe frequency in run time. I also saved a few bytes in the process as I could get rid of the uint16_t too.
Strobe seems super stable running with the delay_5ms function.
Added ramping too and still got a few bytes left to play with so if you got any ideas. But in another thread there is a guy that wants to set his own modes and this got me thinking if anyone has written a firmware that is completely empty and you have to program the modes yourself? That would be a bit cool actually. If you want ie 65, 32, 100, 42 you can have it that way.
Was going out with the dog in the night and wanted something to play with so I made an almost empty firmware, only took a few minutes. Only got one mode full blast by default and then you would have to program all other modes by yourself. I tested it right now in the night and itās a bit tedious but you can have your own exact group as you wish. I set a limit on max six modes but can be increased easily if wanted.
This is very cool can you program the turbo step down on the fly like dr jones guppydrv also?
How do you program it when its in the light? would it work with a twisty? or is it very many very quick clicks that would make it hard to do in a twisty?
And can you reset the modes whenever you want later?
RTFM! Iām a flashlight noob and donāt know much about twistys. But you program the firmware with making 10-19 short presses and then you count flashes and switch off when you get the value you want. IE if you want 90 seconds turbo timer you make 11 short presses and then count 90 flashes and switch off. If this works with a twisty I donāt know.
Edit: And of course you can set all settings as many times as you want.
Iām still updating my firmwares if I find anything broken or missing so maybe better just put a link or something. BTW, how do you rename links in your sig?
A twisty is the colloquial term here for a flashlight that donāt have a button for on off, but you twist the body & head to turn off & on
Often used on small AAA size & smaller lights, to be able to build them smaller & shorter than if they had a switch. The downside is more than a few modes is a hassle on them, because you canāt twist as fast as you can push a button, especially with one hand.
But for programming them when needed, it sounds manageable
Does it have the basics like low volt protection shut off & step down & such features? Sorry if this is all spelled out in the manualā¦ā¦
Yeah I understand what a twisty is but I donāt got one myself. But thinking about it I do got an old mini-mag but I donāt count that one. There is only low voltage shut off right now but thereās plenty of space left so Iāll add step down too. Just to copy and paste some code from one of my other firmwares anyway.
Iām treating the code repo somewhat like a Linux distro. The projects there arenāt expected to be 100% complete, just mature enough to be usefulā¦ and updates over time are totally fine. The idea is to get all the good stuff in one place as a convenient and curated collection.
HTML.
BLF allows a large subset of HTML in posts and in signatures, so you can do a regular <a href=āhttp://fooā>Foo!</a> to make a link.
None of my firmwares support dual-pwm even though theyāre kinda prepared for it. As you say it will get a tad complicated as different people will have different opinions on how itās going to be used. Just setting both outputs to the same value is easy though. And yes Iām using phase for full output (mostly just doing as ToyKeeper says :laughing::
I havenāt thought of battery check, yet. Donāt think Iām gonna bother with it but you should never say never. If I do it I think Iām gonna hide it in 30 short presses or something like that. Will maybe have to throw out something else to make it fit though.
