The problem is solved.
Sorry for the inconvenience caused.
Thanks!! I see it is fixed.
Your wishlist problem still exist. If you click on anything in your wishlist, you get a “page not found” error.
Thanks friend.
Yes. I am getting the same error.
I would pass to our technical support to solve out the problem.
Thanks for your reporting.
KD Coupon Code for all BLF members
Coupon Code: blf (5% off)
Enjoy
Thanks
Nice!!
I tried it and it didn’t work.
If the item is on discount price, the coupon code will not take any effect.
If you still have any question, please let me know.
Thanks
actually a bucketload of tints for the XHP50 and XHP70 now :-)
Thanks for the code…
I've bought the Blue KD buckle v6 ChibiM mentions in the first post and was surprised how good it was for $5. The BLF code can be used too, which brings the price down to $4.75. They also have a set of 4 for $20 or $19 with the coupon.
http://www.kaidomain.com/product/details.S009518
I use it with an Ultrafire 10440 Lion. The torch came with lube on the threads and is very good quality. Has a noticeable hotspot with good spill.Runtime with a 10440 is about 25 minutes. Really nice product for the price. I'd recommend it to anyone wanting a small AAA/10440 torch with good brightness. Mine didn't come with a buckle.
UranusFire C818 Cree XM-L2 U2 1000 Lumens 3-Mode LED Flashlight - Black $24.91 $23.66 after BLF discount.
Brand: UranusFire
Model: C818
Flashlight Material: Aluminum Alloy
Flashlight Color: Black
Emitter Brand/Type: Cree
Emitter BIN: XM-L2 U2
Color BIN: White
Total Emitters: 1
Battery Configurations: 1 x 18650 / 1 x 26650 Li-on batteries (not included)
Switch Type: Clicky
Switch Location: 1. Tail Cap (On/Off)
2. Middle of the Flashlight (Change Mode)
Modes: 3
Mode Memory: -
Mode Arrangement: Hi > Low > Strobe
Brightness: 1000 lumens maximum brightness (manufacturer rated)
Runtime: 2 - 3 Hours (manufacturer rated)
Lens: Coated Glass Lens
Reflector: Aluminum Textured / SMO Reflector
Carrying Clip: -
Carrying Strap: Yes
Other Features: Waterproof IPX-4 Standard
Size: 175mm (L) x 55mm (Dia. of Head) x 35mm (Dia. of Body)
Weight: 280g (not include battery)
Package Content: 1 x UranusFire C818 Flashlight
UranusFire 802 Cree XM-L2 U2 1000 Lumens 5-Mode LED Flashlight - Black $14.66 $13.93 after BLF discount
Brand: UranusFire
Model: 802
Color BIN: White
Total Emitters: 1
Battery Configurations: 1 x 18650 batteries (not included)
Switch Type: Clicky
Switch Location: Tail Cap
Modes: 5
Mode Memory: -
Mode Arrangement: Hi > Med > Low > Strobe > SOS
Runtime: 3 Hours (manufacturer rated)
Carrying Clip: -
Carrying Strap: Yes
Size: 127mm (L) x 24mm (Dia. of Head) x 24mm (Dia. of Body)
Weight: 96g (not include battery)
Package Content: 1 x UranusFire 802 Flashlight
I couldn’t resist the little red AAA light at $4.75. If that order works well I will start to put this company on my safe list!
If you’re referring to the KD buckle v6, I think you’ll be very pleased as it’s great value. I have one and use it with a 10440 battery. The brightness is very usable and surprisingly bright for such a small flashlight. I haven’t checked with a light meter but I’d guess it as around 100-120 Lumens with the 10440.
KD used to be very popular in the past but as other sellers appeared they were almost totally forgotten about. I’ve not had any bad experiences with KD with the few purchases I’ve had with them. One annoying aspect of their site is the searching feature and also their habit of leaving old out of stock items still listed.
Would that be White Cool?
Interesting pattern that apparently describes how the driver works, anyone recognize that?
