I ordered one from Amazon based on HKJâs review. (Thanks!) It arrived in four days without premium shipping. It does appear to be identical to the unit pictured in kaiserâs post.
I use it to run my âXTAR VC2â Li-ion charger, which uses USB power and was previously connected to my Apple iPad power supply. The other ports are handy for charging tablets and phones using short USB to Lightning connectors available on eBay.
Thatâs interesting: The name on the circuit board pictured is âvinsicâ. Iâve bought 2 identical looking units with this brand name (vinsic) some time ago at Amazon.de. The Model No. is VSCW502 and the specs are almost identical to the one above. (smart outputs, 8AâŚ) Nice to know that these prob. will be of the same quality tested and approved as the Eachine above. Compared to other similar multi-output devices Iâve tested (Anker 40W, Tecknet 50W) the Vinsic has a little low output voltage acc. to my measurements (with charger monitors). With 1A load still at 5.02V it drops to 4.92V at 1.8A load. The voltage level of the other brands is a bit higher which can be a good thing in order to gain the max charging rates with USB units.
â the label in the BangGood picture says Manufactured by âShenzhen Shebel Science and Technology co.LTDâ
(note lower case and no space in âco.LTDâ)
â the label pictured in the review here (first post) differs in that last bit
(having a comma after the period: âco.,LTDâ
Trivial difference, but thatâs what we look for to identify fake battery wrappers, so I have to ask.
Same long model number in the two pictures: ZQW121123050805
and âoogle finds upwards of 600 hits for that, several different brand names on whatâs presumably (one hopes) the same thing.
Just concerned that itâs possible to get the same board with parts left off to save money, as observed on seemingly identical hardware of other sorts.
Who ya gonna trust? Nobody, without verifying.
âoogling finds a variety of variations, for example:
Note the various differences in the output power label too.
and âoogle on the model number (above) finds an Amazon model listing a different manuufacturer
âdirected by FLOUREON manufactured by Zhengbaiâ
At least the Model number and manufacturer as well as the rest of the inscription on the side of the box looks identical. It seems like one OEM manufacturer (Shenzen Shebel ScienceâŚ) sells his products under various brand names, maybe for different markets / world regions.
If itâs the same as in OP then no, it is glued (âThere was no easy way to open the box, I had to break it open and it was a bit difficult (This is good).â)
I you are samrt (smart) then keep it in one piece.
According to the images it looks identical to what can be seen in HKJâs teardown.
Furthermore, it seems that at the beginning of the month one could buy this unit from banggood for $15.99 shipped, but right now the coupon no longer works - The cart amount just goes down to 0$ and you cannot proceed with the checkout process. Oh, and they are out of eu plug version as well :_(
If someone manages to buy this one from banggood at the lower rate, please let us know.
Haha I donât think so⌠Looks more like a bug to me.
I have just sent them a message using their chat system about this issue.
Let see what will they say.
In relation to the products being discussed in here, I would really like to have some more info about the Ankerâs 40W 5 port direct knock offs.
They all seem to be very similar design-wise, so I assume they are all the same, or very close to be.
I also assume that they are not equal to the Eachine PA40W, as everything similar to that model, has the same shell, and the same model number (and ~10$ higher price tag).
The Ankerâs knock offs donât have those âfeaturesâ.
I own the Anker 5 port 40 watt charger. I only charge my Nexus 7, Moto G, and an iPod Shuffle with it. It works flawlessly and runs cool. I leave it plugged in 24/7.
Thanks for the input.
Even though not professionally tested, Iâm sure that the original Anker product is excellent. It comes from a well known brand and has lots of good reviews.
The sad thing about this product is that Anker wonât ship it internationally and therefore I canât purchase it.
Iâm about to buy either the BlitzWolf unit, or one of the Anker direct knock offs, but I need some more info first.
I need the info because my entire idea is to get some high quality product, as I want my phone to last, and me being safe
HKJ, what do you think about a review of one of those Ankerâs clones?
I bought a number of Vinsic 40W power USB adaptors (VSCW502)
They are good for charging mobiles, but I donât think that they are good for powering a Raspberry Pi. While I have not done a proper test, it seems to me that the output current drops over time - leading to instability in the computer
