I am fine with 30 second step down for a good safe Turbo session. I would rather have this light available with “only” thirty seconds of ~1500+ lumens that I can use with the other modes, than a light that goes “phfffft” one day I am feeling froggy on seeing how much heat I can handle…
You can discus this endlessly, piling safety margin on top of safety margin, but it just needs a test, with a high drain battery, tailstanding, with high enough ambient temperature. The turbotimer can then be set at what the light can handle, 30/60/90 secs or whatever it will be.
I do agree that if getting this light suitable for unaware (stupid) folks implies bargaining too much on the performance, then it would not be a true BLF-light anymore.
But it looks like we're on the right track for both kind of people
NO timer for turbo .
Ultimately... :) .... Whatever TK says she is going to do with the code is what is going to happen :) I do not think any one of us in the group will not go along with her recommendation. If she feels it is too hot..then it is too hot.
Someone asked about LVP (low voltage protection). It does have that and even has a battery check feature in the hidden section.
I believe somewhere in this thread are all of the features but honestly I cannot say where. It is my fault that I did not include it in the OP. IF TK finds the time to list and post the features I will post them in the OP. With that said, the ability alone to go from 7 to 4 modes and reverse is the cat's meow. Even I, who likes mode memory, find that even starting on moon and jumping straight into max to be easy. That should even satisfy the 2-mode people :)
What this light does not do is clean the house. LOL.
Think about it:
- Max people
- Moon people
- 2-mode people
- Bicyclists
- Low Voltage Protection
- Battery check
Like Dale said....this UI just needs to be implemented in ALL lights
As I said earlier - This light is a “Must have”
This is TK's current write-up on the BLF A6 firmware, pretty detailed: http://bazaar.launchpad.net/~toykeeper/flashlight-firmware/trunk/view/head:/ToyKeeper/blf-a6/blf-a6.txt
Thank you Tom!!!
+1 Yup, this is very true and I trust the consensus of the experts here….
No, it just drops directly to the previous mode.
Thanks for the reminder. I forgot to update that after I added things to the code, so I updated it just now.
A short(ish) list of the light’s features:
- FET+1 driver for both maximum output and stable low modes, should do about ~0.3lm to ~1500lm on the stock light.
- Standard-sized 18650 tube light host with good anodizing and (I think) BLF logo. Uses a reverse-clicky switch and can tail-stand.
- Copper MCPCB with direct thermal path to handle the high power.
- Two options configurable without opening the light:
- 7 or 4 regular modes starting at ~0.3lm or ~10lm depending on the config.
- Mode memory can be turned on or off.
- Modes are evenly-spaced according to selfbuilt’s cube-root model of light perception.
- Offtime-based UI which detects short/med/long presses to go forward, backward, or to the first/memorized mode.
- Low-voltage step-down and shutoff.
- Turbo step-down (timer-based, time not yet determined).
- Hidden blinky modes:
- Tactical strobe
- Biking flasher
- Battery check / beacon
- PWM is fast enough to be imperceptible (19 kHz), and blends the two power channels to make tint shift gradual.
- The MCU is flashable, and the code and driver designs are available for anyone who wants to modify them.
Approximate runtimes based on DBCstm’s power measurements and a 2500mAh IMR cell:
- Moon: ~11+ days (TBD)
- Low: ~3.5 days (TBD)
- Med 1: 17 hours
- Med 2: 6.5 hours
- High 1: 100 minutes
- High 2: 50 minutes
- Turbo: 26 minutes (but not recommended for more than 60 seconds)
- Tactical strobe: 53 minutes
- Biking flasher: 5.5 hours
- Battcheck / beacon: ~17 days? (TBD)
can´t wait to hit the [order] button!
thank you all for your great work!
I'm really interested in this light. I've been reading the thread, but it's pretty long. Can anyone tell me the approximate level of the moon mode?
I know it will vary for different cells.
0.3lm-0.7lm depending on mode you are in
DING! DING! DING! We have a winner! Please put me down for 1 in NW
Tom E thanks for posting the details. I can’t wait to for this GB to come through
I’d like to sign up for a nw.
I'm just glad to see "our" custom firmware make it into a nice production run. Everybody is doin what they are good at - from firmware to making drivers/lights. Of course TK doesn't make any $$$ on it - can't say Eagle Eye or BangGood are making much either, but if this gets pulled off where the majority is happy, we all owe TK something. I know she's leveraged some things from BLF or BLF'ers, but the majority is on her.
Rolz - thank TK, not me...
Interested in purchasing at least 1 N.W. BTW, thanks to all who made this Group Buy possible
+1
At Least 60sec, please…
At my age, sometimes it takes me sometime to realize just what it is I am looking at:-)
90sec would be great, but thinking more about it (after reading other’s posts) - No stepdown would work for me too.
If I don’t forget that the pain in my hand means that I am being burnt:-(
The way that this light is built, I would venture a guess that it is able to stand more that I/We. - Great heatsinking will make the outside of a High-Powered light heat up FAST, if the Sink is well connected to the exterior.
Thanks,
-Chuck
