I got this radio a month ago but got a problem with the power output.
If i use try to select high/med/lo transmit power on a saved frequency it always default on high i can’t set it at med or lo,meanwhile when not use a saved frequency i can set it either high/med/lo.
Anyone got the same problem as me?
Ooooh , you should be able to default to low or medium power VIA software ( CHIRP )
To change power on the fly , try the #Key ( bottom right of keypad )
And if you are in Australia :
Its not legal to use a Baofeng on CB frequencies , to posses a baofeng is a Breach without a license .
And it is a breach if it can operate outside the band plan ( 144 - 148 / 430 - 450 )
In Australia Foundation license holders have been targeted .
Penalties are harsh , with up to 5 years in the pokey ! + A large fine ...
Want a Baofeng without a License , then you need to disable Tx .. ( Permanently )
I have seen the UV-5r sold as a 80 Channel CB ( This is not Legal ) on a certain site , he is begging for a rap on the knuckles ...
I have made some minor improvements to my GT-3 ( Antenna + Battery ) and its better now .
I have seen the GT-3 TP ( Tri Power or MK3 )
But the Baofengs leak power quite a bit , I will have to re-visit this one day .. So I dont like using the hand helds on anything but low power .
Thank fully the new antenna works well ,
Im using the Nagoya NL-R2 , and the Li-ion UV-5r ( Big ) battery on the GT-3 ..
Performs much better than the stock GT-3 ..
I am KB3OYZ, hi guys…
i was always gonna TRY one of the cheap 2m hand rigs always on ebay and such… it wouldnt take much power for me to reach my local 2m repeater tower that a local club (MARC) keeps up.
I dont know about the OTHER countries, but, here in the US ?
any licensed HAM operator is allowed to own/MODIFY/use … “any” radio equipment, it is assumed as a licensed amateur, you are knowledgeable enough to ensure you are not transmitting on “no no” frequencies.
for instance, the 25 or 35 watt 2m mobile rig i used to run in my delivery truck for several years? it was perfectly legal that i opened up the freq’s, so i could LISTEN to the many local police departments that use the same freq just out of 2m… i am trusted not to transmit on that freq, naturally.
it was handy to drive around letting the rig “scan” my 2m repeaters i talked on, and if there was no action, it gave up local police calls too.
but thanks for the write up on the rig… i remember the baofeng name for cheap 2m rigs, wasnt there another cheap chinese name in 2m hand rigs too? cant recall it now…
There are several ( Cheap ) chinese brands , Baofeng is the cheapest .
I go window shopping at the 409 shop http://www.409shop.com/
old4570,
Is that battery mod difficult to do? Would you be willing to explain how it was done? I would love to get a bigger battery onto something other than uv-5r.
Thanks
http://www.eham.net/ehamforum/smf/index.php/topic,98691.msg782307.html#msg782307
Pretty much the same way as I did the AA battery case mod .
In fact I would recommend you buy a AA case , and mod it first .. ( For the experience )
I was planning to purchase the GT-3 MK III but after reading this review…I am considering the Baofeng UV-82L.
Any comments between the two?
73
You can always check “E-ham” but like Amazon reviews you can’t rely on everything you see there as being accurate. Still good for finding common issues and problems and sometimes the solutions for them.
Phil
I just got my Mark III a few weeks ago, I was lucky enough to spot a sale item which came with the 3800mAh battery! It is big and clunky but lasts literally forever. Have been listening and scanning a few minutes every day and even after all this time I haven’t had to charge it yet!
But the AA battery mod is something I would prefer because the car charger solution is a joke. (putting the device into the (desk) drop-in charger while driving is not that great)
ps: I still don’t have the CHIRP cable yet and the plastic/chrome on/off switch is a turn-off. Need to replace it.
The Mark III is actually a good device for the price. 8W is true for me, have significantly increased performance with a good antenna. the one in the package is not bad either.
Remember to use Baofeng BF-F8HP in the CHIRP program for the GT-3 Mark III TP and not the Baofeng UV-5R (for the GT-3 Mark II) when you get your cable.
I have the 888 for random convoys (when driving, not the lights ) . They are the usual Baofeng quality and come without any issues, at least for me. The UV5R accessories won’t all fit (ie batteries), some will fit.
What are you doing with the radios? Just the common driving, hunting, hiking, … activities?
yes…in the forest,by skying….etc
A bit of an updated :
If you throw on a better antenna , the GT3 becomes a serious bit of kit …
Nagoya NL-R2 works insanely well …
Kinnota AZ507R is even more serious an antenna but possibly too long …
You will need a SO-239 adapter … To go with PL-259 antenna …
Once you throw on a better antenna the GT3 begins to really impress … If you own a GT3 consider the NL-R2 as a must have …
I second that - a good antenna makes all the difference.
Just finding a genuine antenna can be tricky! What Latticebright is for flashlights is the same as a cloned antenna for ham radios. If you have a trustworthy store/shop only buy from there, not just from the cheapest ebay seller.
Do you know any good stores.i bought the rh660S from Banggood it’s s good antenna just not practical it’s 1 meter long lol. I have a Nagoya and also another diamond. It’s meant to be made in Japan.
Ebay is flush with antenna …
http://www.409shop.com/ I have purchased quite a few antenna from 409shop
Thanks mate.
Do you have your VHF license? I am thinking about getting mine.
VK3FORK ….
Definitely need a license to play
