Did some current readings but unfortunately with only two Samsung 25R-s. So the final result should be slightly better when the third one kicks in.
Levels from 1-6:
Does anyone know how well the Courui responds to a MT-G2? Primarily I am interested in maximum throw. I know that the mt-g2 is a very large led and can be difficult to get to throw well.
Thank you for your offer, maybe in near future. I have to get my hands on something new to work on before selling this one.
I Didn't weight it before but now it is 560g without batteries. It's heavy in hand.
This really took a lot of patience to finish. Like 2 months of patience .
Yes, it's a real shame. But it is now posted here on BLF where people will appreciate this kind of work. Good comments and a killer thrower is all I need.
Thanks Old-Lumens, I learned a lot from your posts and You tube videos. You are one of the reasons that I got myself into this great hobby.
This helps a lot when you try to solder bigger pieces http://www.banggood.com/MT100-Cordless-Gas-Soldering-Iron-Gun-DIY-Welding-Iron-Melting-Torch-p-926639.html
But first you have to apply solder on both sides completely covering the surfaces. When applied and cooled, use blowtorch (or a powerful soldering iron - min 60W) to melt it again and press it so that excess solder is pushed out. I prefer using small blowtorch like one I linked above because it is much easier to heat up objects. For a few dollars you get a very good tool to do this kind of work.
