I’m sure there probably are. These were available and had youtube reviews and I didn’t really want to go with more cells. They were what I found when searching the net. Lots of boost converters, probably meant more for 12V automotive than anything else.
Great build as always, can't wait to see it finished.
Correct me if I'm wrong but this looks like protection circuit board (PCB), not a battery management system (BMS). This should work in charging mode but only with that charger that You bought that has a end cut-off voltage. BMS would work with any power supply with correct voltage. Hope You can provide status of every single cell in this battery pack after a few charging and discharging cycles. That would be very interesting.
PCM, but from what I read, besides balance charging, it also manages output, so that no one cell is getting very low. If one cell is lower, it “supposedly” balances the power to the other cells, but that may just be my lack of knowledge. I certainly don’t have a clue about these boards.
Every time i see a new flashlight build by OL a popcorn comes to my mind
About this boost converter does it give constant current ? i had used converter like it called qskj also bought it from aliexpress and it was working perfectly
Justin, I didn’t know until I was looking at it on the PCT the other day: this CXA3590 takes over 42V to reach its highest rated current draw! But, it starts at ~35V on the bottom end. That is a HUGE jump! If a person wanted to, they could use 10X 18650 or 26650 cells with a DD/FET driver (assuming the driver can handle up to ~42V input/output) to power one of these. I know that’s not what you’re doing with this light, but maybe the other CXA3590 could be powered this way?
