in order of use incandescent bulb and have enmity to cfl bulb try to buy led it is best for you with use incandescent bulb no problem solved
use cfl in cold air reduce their life and decrease their shine
incandescent bulb have short life and in order of long use they malfunction due to field of tungsten heat this is just increase your charge to replace them
if led can not brighten area try to double or triple it via add more light socket
in any case you use led bulb that is more beneficent for you
Counting appliances I probably have 8 or 10 incans left in areas where the light is not left on for long and/or I want instant light. I started gradually replacing them with CFLs years ago, I’m now replacing the CFLs with LEDs. At this point I probably have 60% LED, 30% CFL and 10% incan. LED is the only bulb I’ll buy.
I have quite a few brands, haven’t had a dud yet but I’d say I prefer the Crees. The light is adequate for the watt equivalence (40-100), tint is good both cool and warm, they’re readily available and priced well around here.
I have a couple of CFLs in my master bath and in a reading light by the bed. I like the fact that they come on dim at first.
I have 5 outdoor, double 250w halogen lights to replace next, just bought an outdoor, LED floodlight but haven’t put it up yet. I’m disappointed at the limited, high priced selection of outdoor LED lights.
Having spent time on this forum and built 50 or so lights I know there’s no reason we can’t have decent, high output outdoor LED lighting.
The light I just bought for $100 has three heads each with a single, cool white LED. It’s rated at 35 watts total for 2,500 lumens.
Really? Large, finned aluminum housings hard wired to 110V and all I get is 2,500 cool white lumens? C’mon!
I’m switching over to mostly CFL’s since I had a bunch sent to me free courtesy of the local power company. I just pop a good one in when an incan dies and I’ll get there with the process eventually. Most of the time the only light on here is my only LED bulb; a Sylvania 40W equivalent on my desk. I don’t like the 2700K color but it was free and I ain’t rich or complaining! There will always be an Incan at my radio desk to keep RF noise down; that’s the only situation I know where the old is better than the new!
> amber … midnight snacks
Yep, that’s the reason — to be able to snack without having trouble going back to sleep.
Incandescent because, well, it’s what I found available at the hardware store 20 years ago and they’re still working fine.
Amber coated 25-watt bulbs from Ace Hardware.
Being incandescent the color rendering is very good because it’s a continuous spectrum, just with the blue end cut off — not a narrow LED amber emitter but rather an amber ‘color temperature’
I moved to CFLs years ago as soon as they started becoming moderately affordable. Due in large part to the reduced electric bill, as they use less energy, and dump less heat into the house, requiring less energy to A/C back out. In NE Texas, humidity is very high, 90%+, the summers are about six months long, and 100+F days are common, so we already run the AC a lot. I preferred the CFL and LED bulbs for the increased comfort caused by not pushing all of that heat into the house.
At this time, I have five incandescent bulbs in my house that I can think of:
In the garage door opener
In the microwave oven
In the conventional oven
In the freezer
In the attic (as the incan bulb can take being left in the severe heat all summer)
I've been primarily using CFL bulbs, but am now migrating to a larger number of LED bulbs, due in part to (Shill-On!) Lowe's new low pricing on their Utilitech bulbs (Shill-Off!)
My largest frustration is thatlight manufacturers have switched to the "Specialty" E12/Candelabra base fixtures. Now I'm stuck having to buy extremely overpriced E12 CFLS, while affordable LED replacements have been impossible to find. I have a drawer full of unused incan bulbs taking up space now, that I have no use for, courtesy of this change...
If you’re a little bit handy with a screwdriver and a set of pliers, you can buy replacement sockets at Lowe’s in the Electrical and/or lighting department. I did that once, because I bought a ceiling fan that came with four sockets for those worthless “High Output” bulbs. The socket size is just larger than a candelabra. After changing the sockets, I put four “100W equivalent” CFL’s in them and had some real light!
95 % of my house is now LED, with a couple CFL and only three Incan in the three outdoor motion lights. (the LED bulbs seem to flicker in my motion-light fixtures.)
So you’ve never eaten green/furry meat/cheese/milk/etc? It’s not very tasty…
I just had a Sylvaina 10W/95CRI/PAR20 bulb die in the kitchen. The fixture it is in is hell on bulbs. It has killed lots of halogens and one other LED bulb.
My house has around 300 LED bulbs. The only hot-wire bulbs are in the fridges and microwaves/ovens… they don’t count. No CFLs… never had ’em, never will…
Garage door openers are hell on incandescent bulbs. The vibration kills them… even the ruggedized specialty bulbs. They were some of the first bulbs I LED’d and have never had a failure since. The old incandescent bulbs even melted/cracked the sockets and discolored the bulb cover.
I have 3 x 100W eq CFLs, and the rest are 60W eq LED (purchased for $5 each or less). Hopefully the CFLs last a few more years then 100W LEDs fall in price. I put a 60W eq LED in the fridge to replace 40W incandescent, it is amazingly bright now!
I calculated the fridge bulb saves me 15 cents a year based on fridge open time, electricity saved and reduced heat generation
