Test/Review of Samsung ICR18650-22F 2200mAh (Green)
9 posts / 0 new
HKJ
HKJ's picture
Last seen: 6 hours 57 min ago
DSC_9402
Official specifications:
  • Nominal Capacity: 2200mAh
  • Charging Voltage: 4.2V ±0.05 V
  • Nominal Voltage: 3.6V
  • Charging Method: CC-CV (constant voltage with limited current)
  • Charging Current: Standard charge: 1100mA, Rapid charge : 2200mA
  • Charging Time: Standard charge: 3hours, Rapid charge: 2.5hours
  • Max. Charge Current: 2200mA
  • Max. Discharge Current: 4400mA
  • Discharge Cut-off Voltage: 2.75V
  • Cycle life: 300 cycles to 68%
  • Cell Weight: 44.5g max
  • Cell Dimension: Diameter(max.):18.4mm, Height: 65mm max
  • Operating Temperature: Charge : 0 to 45°C, Discharge: -20 to 60°C
  • Storage Temperature 1 year: -20~25°C, 3 months : -20~45°C, 1 month : -20~60°C
Samsung%20ICR18650-22F%202200mAh%20(Green)-info
The datasheet for this cell says 2008, i.e. it is a old design, this can also be seen on the limited capacity and current capabilities.
DSC_9401
DSC_9403 DSC_9404
DSC_9405
DSC_9406
Samsung%20ICR18650-22F%202200mAh%20(Green)-Capacity
The discharge curves looks good enough, good tracking between the cell when not overloaded.
Samsung%20ICR18650-22F%202200mAh%20(Green)-CapacityTimeHours
Samsung%20ICR18650-22F%202200mAh%20(Green)-Energy
Samsung%20ICR18650-22F%202200mAh%20(Green)-PowerLoadTime
Samsung%20ICR18650-22F%202200mAh%20(Green)-TripCurrent
Samsung%20ICR18650-22F%202200mAh%20(Green)-Charge
Conclusion
Not the most interesting battery today, but the cell is good enough within its limited capabilities and it can easily surpass some cheap brands.
Notes and links
Compare to 18650 and other batteries
djozz
djozz's picture
Last seen: 4 hours 50 min ago
Thanks for the test. If these are cheap, they have their purpose I guess.
vēer
vēer's picture
Last seen: 11 months 2 weeks ago
I dont understand – do these come with protection circuit or not?
How do they cut off at 2.75V?
What are they good for, aside from lower capacity?
Ronin42
Ronin42's picture
Mine dont set any records but for my C8/S7 lights they work just fine.
(“It’s good that most people can’t remember their previous lives. Otherwise
things would be a lot more complicated than they already are.”
Ajaan Lee Dhammadharo)
HKJ
HKJ's picture
vēer wrote:
I dont understand - do these come with protection circuit or not? How do they cut off at 2.75V? What are they good for, aside from lower capacity?
No protection board and you must control the cut-off.
Today they are old cells and not very interesting.
vēer
vēer's picture
I see, thanks, folks!
Ive noticed that Gearbest have them for 2.85$ per cell, so wanted to know whether I should buy a couple for lights:
http://www.gearbest.com/batteries/pp_196911.html
vēer
vēer's picture
So I bought them back then and now pulled out of storage to charge and use in light for the first time :D!
Nothing to report, 3.6v after years of storage, not bad, huh?
Barkuti
Barkuti's picture
Last seen: 8 min 25 sec ago
Do you remember at what voltage your cells were stored? That is a meaningful detail to determine the overall outcome. If you stored the cells fully charged, bad start.
You can use an analyzing charger to see how they're doing capacity wise.
Cheers Smile
The Light Innocent I am
Deleting a post and redoing it causes the forum thread answer notifications to become invalid. Thus, if you need to change your just published post, edit it. Thanks.
Please avoid quoting lenghty posts, namely with nested quotes. Trim the quote down to the essential. Helps with forum neatness and legibility. Thanks.
Localized AliExpress links mess up with the language setting of whoever clicks or taps on them. While this is a fault of the AliExpress system, turning localized links into global links helps and is easy; just change the locale letters in the url for www. Example:
https://es.aliexpress.com/item/bla-bla-bla.html turns into https://www.aliexpress.com/item/bla-bla-bla.html. Thumbs Up
vēer
vēer's picture
To be honest, I dont remember, but you can check out my experience with Pananocis 3400mAhs, no scientific data:
After storing some of my Pana’s protected 3400 ICR’s(green ones) for a year fully charged, not properly “cycled” and rarely used before being put into storage and/or after being taken out from storage showed 3000-3100mAh capacity with Lii-500 charger.
http://budgetlightforum.com/node/44115
Will see how well these green Samsungs hold up after couple of cycles as my bicycle light batteries on S2+.
